asus pg258q gives better results at 120hz than 240hz
ballot
Post by ballot » 30 May 2018, 09:11
Hi when i use my monitor at 240hz + gysnc , browsing web
as example when i am scrolling page down i see some blurring , also in games too
but 144hz + ulmb makes me feel much better in games and in reading texts too,
not sure how to name it but i can show
this one is 240hz + gsync results Image
this one is 144hz + ulmb results Image
look to the ufo in the middle , the 240hz has always leaves something behind when background is lighter and its clearly visible
is it normal , can i fix it?
my gpu is gtx 1080ti best regards
mello
Re: asus pg258q gives better results at 120hz than 240hz
Post by mello » 30 May 2018, 09:32
Although your photos look contradictory (and not accurate) to me... but still:
ballot wrote: look to the ufo in the middle, the 240hz has always leaves something behind when background is lighter and its clearly visible
When using 240Hz+GSYNC, use Normal OD setting, and not Extreme. This should fix the problem.
ballot
Post by ballot » 30 May 2018, 09:47
mello wrote:Although your photos look contradictory (and not accurate) to me... but still:
Chase Test with background white
240hz + gysnc : Image
140hz + ulmb : Image
as you see the orange bar's a part is totally red always, when i made the test as first i thinked test's normally as that.
and now i tested with closing OD. it now worked fixed the bugs. but what exactly is OD.
thank you anyway
Post by RealNC » 30 May 2018, 10:02
Vipu
Post by Vipu » 02 Jun 2018, 16:39
Well, that is what ulmb does? Removes blur.
Post by Chief Blur Buster » 02 Jun 2018, 17:22
It's normal for 144Hz ULMB to be sharper than 240Hz non-ULMB.
This is just a normal feature of strobe backlights. We've noticed this behaviour with LightBoost a few years back where even 100Hz LightBoost was much clearer than 144Hz:
Currently, right now, it would require approximately a ~1000Hz display to achieve the same motion clarity as modern ULMB displays. A good educational article about how to reduce motion blur without strobing (ala LightBoost/ULMB) is found at Blur Busters Law: The Amazing Journey To Future 1000Hz Displays.
Blur reduction via strobe backlights:
4ms flash = 4ms MPRT persistence
2ms flash = 2ms MPRT persistence
1ms flash = 1ms MPRT persistence
Blur reduction via flickerfree ultra-high Hz
4ms refresh cycle (~240Hz) = 4ms MPRT persistence
2ms refresh cycle (~480Hz) = 2ms MPRT persistence
1ms refresh cycle (~1000Hz) = 1ms MPRT persistence
So that's why low-Hz strobing can sometimes look better than high-Hz unstrobed.
Advanced Users Only: Also, if photographing, we usually do pursuit camera". Pan your smartphone sideways while taking a picture. A moving camera lens is an equivalent of a moving eyeball. You must track lens whether it's a camera lens your human eye, for accurate perception of display motion blur. You can use the ladder track (Sync Track) at http://www.testufo.com/ghosting and make sure that the tickmarks align. Display reviewers use a camera rail -- many testers use our motion test inventions -- but some creative end users can carefully hand-pan their smartphone sideways while taking a photo. Just make sure that the ladder track (Sync Track) tickmarks align up in the resulting photo, just like it does with your human eyes.
Post by RealNC » 03 Jun 2018, 02:56
I didn't notice you're using ULMB.
Yes, 144Hz ULMB is much clearer than 240Hz non-ULMB. In fact, even 60Hz ULMB is much clearer than 240Hz non-ULMB. 60Hz ULMB is usuallyy as clear as 1000Hz non-ULMB.
Why do you think so many people here still love CRT monitors? :mrgreen: They're even better than LCD monitors with ULMB.
