I would like to use FreeSync while also bitstream audio to my receiver. Has anyone found a solution other then the ASUS Xonar HDAV (the pci-e version is unavailable/stupidly expensive)?
Before you post, things that don't work:
I know of no receiver with VRR compliant passthrough
Using two different slots on your VGA for the display and receiver doesn't work because you need to go into multi monitor mode to transmit the sound. Freesync doesn't work in multi monitor mode.
There are no HDMI splitters with confirmed VRR support. There is one that claims VRR support but people reported it didn't work.
The ideal solution would either be a VRR compliant splitter or an external USB to HDMI audio device. Do you happen to know a device capable of doing this? Thanks in advance!
FreeSync + audio bitstreaming?
Re: FreeSync + audio bitstreaming?
Interesting use case -- switching VRR through a receiver.
Yes, that is something that needs more testing & validation. Especially with receivers that overlays graphics on top.
Haldi
Uhm, sorry i don't really follow...ChiefBigFeather wrote:I would like to use FreeSync while also bitstream audio to my receiver.
By Bitsream you don't mean the normal PCM Signal that is sent via DP/HDMI but the Dobly Digital encoded one like DTS-HD?
i'm currently using a Samsung C49HG90 via Displayport from my Vega64. Freesync works.
For sound i use the HDMI Port to the Denon AVR-X1000 then a HDMI-DVI Adapter to my 2nd Monitor. But i'm pretty sure that also worked when no monitor was connected after the AVR.
- Sound.PNG (64.45 KiB) Viewed 17676 times
It's also possible to use HDMI-to-Toslink splitter, but I don't know if those support FreeSync VRR. There's been failures to passthrough FreeSync through receivers and adaptors. So it's a bit of a guesswork game at this stage -- trying to pass FreeSync through adaptors.
ChiefBigFeather
Yes, by bitstreaming I mean bitstreaming DTS-HD etc.Haldi wrote:Uhm, sorry i don't really follow...ChiefBigFeather wrote:I would like to use FreeSync while also bitstream audio to my receiver.
Thanks for your input! I heard Freesync doesn't work for multi monitor setups, so I just assumed it wouldn't. Setting up my receiver as a second monitor annoyed me quite a bit though. It caused BSODs with fastsync (double buffer v-sync), but that one doesn't work very reliably on my system either way. I just assumed Freesync would be just as bad.
Using HDMI audio on a pc is such a pain in the ass, I constantly look out for hdmi sound cards. But apparently there are not enough people having this problem :/
supertoast
There is no difference between multichannel PCM 7.1 and bitstreaming Dolby/DTS, TrueHD,DTS-HD other than logo lights up on the receiver.
PCM is much more desirable as it works with all audio sources, many games and pieces of software have no audio bitstreaming features. Run the Windows speaker wizard, if all is working it should see 7.1 audio, select that then in any game or app (e.g. Kodi) set the speakers to 7.1 if it has a setting.
HDMI soundcards are rare because of the above, you just use your GPU's Displayport or HDMI connection to your receiver to send PCM 5.1/7.1 audio.
From my experience on other av forums Displayport is much more reliable than HDMI for connecting up to a HDMI receiver, in Windows the connection has to probe the receiver and direct HDMI to HDMI for some reason often fails this resulting in PCM stereo only whereas Displayport to HDMI cables almost always correctly detect supported audio formats.
If your GPU has a spare DP port try that instead of HDMI, I briefly had a soundbar hooked up to my gaming Freesync PC and dont recall any problems though it was a while back.
The only audio/video splitter I know of with claimed HDMI VRR support is the HD Fury Vertex, that VRR is for Xbox though, I'm not sure if they tested it with PC's.
lossofmercy
Has there been any progress on this area? I really don't want to run another wire from my tower to the entertainment center.
My situation is a 3080 connecting to a LG CX, and two other gsync monitors... so it's pretty complicated. I would like to simplify by just extracting the audio...
