Anyone have a link to an actual specification list of DirectX? That includes rendering limitations?
Or more specifically, does anyone know what the maximum rendering resolution of DirectX/Direct3D 9/10/11/11.2 is?
So far a lot of custom resolutions higher than 4K are crashing several games back to the desktop... I'm assuming there is a resolution limitation of Direct3D that is causing this because the resolutions are running other programs/desktop just fine. Its only DirectX games that are crashing.
DirectX/Direct3D specifications [for "Bullshot" Resolutions]
- trey31
- trey31
Re: DirectX/Direct3D 11 specification question
http://msdn.microsoft.com/en-us/library ... x#Overview
DirectX 9.x programs are limited to smaller texture sizes than DX10 and DX11. More info/specs at that ms page I linked to. But I believe this is what caused issues in a few games at 5120x2880 (16x 720p), 5760x3240 (9x 1080p), and 6000x3375 (arbitrary resolution).
I'm reposting this here in case anyone else can't find the Direct3D and DirectX specs I was looking for.
Also if anyone is curious these work for some DX11 games (not all) with NVIDIA custom resolutions. Good for "bullshots" and thats about it. Over HDMI I had to use manual 1760x990 reduced timings with "Desktop Resolution" set to 5120x2880 and still only got the display to refresh at 29hz. Every resolution bigger than that was only 22-23hz. Definitely not "playable" refresh rates for most games.
