Force more sharpness on 2546
MagneticDev
Post by MagneticDev » 29 Dec 2018, 07:35
Hi,
I have two monitors, one xl2411z and one xl2546, but it feels like the 2411z is more sharp.
Anyone know if there is a way to force more than 10 the sharpness by using the factory menu?
Re: Force more sharpness on 2546
Post by Chief Blur Buster » 29 Dec 2018, 12:09
MagneticDev wrote:Hi,
Question,
Is your problem sharpness, or is it strobe crosstalk?
The higher the Hz, the more strobing reaches limitations of the LCD panel, so one good test is to use a lower Hz, such as the 182 Hz custom timings that are available for the XL2546 via the use of a large vertical total (that puts more time between refresh cycles to finish pixel transitions).
MagneticDev
Post by MagneticDev » 31 Dec 2018, 05:44
I know,
But I talk about sharpness only.
I think when you set sharpness 10 on the 2411z, it's more crisp.
Do you know if there is a way to force more sharp?
Post by Chief Blur Buster » 31 Dec 2018, 13:45
MagneticDev wrote:I know,
No, there is no way to do so.
MagneticDev
Post by MagneticDev » 05 Jan 2019, 04:25
ok :(
thanks
Post by RealNC » 05 Jan 2019, 04:36
In games, you can use ReShade and activate the lumasharpen shader.
