hi I want to buy one gaming monitor for the 2060 rtx
my budget is 200-300 euros..
can we find gaming monitors 27 size for resolution 1920.1080?tN or ips? panel in that budget?
can you help me please?
gaming monitor for rtx 2060?
Re: gaming monitor for rtx 2060?
Viewsonic XG2402 - fastest one
Msi Optix MAG241C - better contrast
my friend I want 27 size monitor and not 24 monitors
can you suggested me 27 size monitors in the budget of 350 euros?
which are the best gaming 27 size monitors in 350 and 400 euros my friend>?
With that budget I couldn´t find a single reccomendation for 27 inches.JohnDongus wrote:my friend I want 27 size monitor and not 24 monitors
Notty_PT, there is the XG2702. It's supposed to be the same monitor, just bigger.
Shouldn't it be the same in performance as the XG2402?
XG2702 is around 300€.
I have found these monitors which is better?
https://www.skroutz.gr/c/43/othones-upo ... nc-TN.html
I want only 27 size and not 24
what is your opinion for this monitor??
https://www.newegg.com/Product/Product. ... 6824236821
