Firmware upgrade using Linux tool, requires no hardware
Re: Firmware upgrade using Linux tool, requires no hardware
If anyone can take a backup dump of their XL2411Z "MX25L1605" firmware I would appreciate it. Begging please if someone can do that for me? Not the "MX25L1605A/E". I need a copy of the first one that comes up when you list the firmwares.
Please..
Thank you.
Please..
Thank you.
Look I'll make a donation for a copy of that first flash file for the XL2411Z "MX25L1605" firmware.
Not the second one. I got that.
Thanks guys
Your all awesome..
Thanks guys
Your all awesome..
Didn't work for me at all.RoSenpai wrote:I was about posting a full guide incluiding this, but I think is unfair since I just changed some permissions.
So please, go on.
The exact problem it solved was the Errno 5, and I think it should work too with Errno 6.
Also, you could update the svn co svn://flashrom.org/flashrom/trunk@1846 flashrom to svn co https://code.coreboot.org/svn/flashrom/trunk@1846 flashrom , I don't know if you did it already.
And for anyone who need it, I have attached the update I used. XL2720Z V5.
It's compressed as rar instead of zip because of the size, sorry.
I AM VERY HAPPY TO REPORT THAT I FINALLY FIXED IT!!!!!!! WOOHOOO!!!!
I just wanted to detail how I was able to finally have some success. Ok here goes. Intel iGpu will F it up. Didn't work for me from across 4 different machines with integrated igpus. Kept on getting errno 6 errors. So finally I dusted off my old Gigabyte Z87X-UD5H hackintosh system and fired up Ubuntu 18.04. I had an Evga 730GT video card in there and used a DVI-RGB cable adapter. I had to break off 4 pins around the horizontal pin to get it to fit. Anyhow its weird how some dvi vga adapters have a long pin extension and others are short but those 4 pins on top and below wasn't letting it go into the dvi port on the back of the card.
So I had to change "deb http://archive.ubuntu.com/ubuntu/ trusty main restricted universe multiverse" to "deb http://archive.ubuntu.com/ubuntu/ bionic main restricted universe multiverse" because 14.04 is already obsolete. I used a copy of flashrom that someone had posted ten pages back and compiled it. Followed the instructions as best I could before bricking it but alls well that ends well. Now on V4 and will be testing this out and see what this all brings to the table.
Want to thank everyone that offered to help via PM. Everyone else that I harassed I do apologize and ask you ignore my messages.
So Nvidia to the rescue today!!!
Thank you
Thank you
can someone update the tutorial for linux and upload links for xl2411z ? i got v1 now
Just follow the tutorial on page 21.akhyg wrote:can someone update the tutorial for linux and upload links for xl2411z ? i got v1 now
download the prepatched Flashrom package that was posted on page 50:
https://www110.zippyshare.com/v/qacsLHgR/file.html
Just copy the folder to your desktop and compile it after you
make sure you 'sudo apt-get install build-essential' before you compile Flashrom
use Ubuntu 18.04 instead but instead of: "deb http://archive.ubuntu.com/ubuntu/ trusty main restricted universe multiverse"
change trusty to bionic. Actually that line already exists but its bionic not trusty anymore. Just add universe multiverse to it.
Use nvidia graphic card. Intel IGPU failed me. Have a couple backup computers to experiment with. Bricking may happen without warning...
Good luck.
The_System
I successfully flashed my BenQ XL2720Z to the Zowie V7 firmware. Thank you all for the tutorials!
Yesterday and earlier today I tried to upgrade from v1 to v7 for my XL2720Z using ubuntu 14.04 lts and the instruction given here: viewtopic.php?f=13&t=779&start=490#p35095.
It all went smooth until the final step ,where I would get an error stating:
ubuntu@ubuntu:~/flashrom$ sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-1:49 -c "MX25L1605A/MX25L1606E" -w XL2720ZV7.bin
flashrom v0.9.7- on Linux 4.4.0-142-generic (x86_64)
flashrom is free software, get the source code at http://www.flashrom.org
Calibrating delay loop... OK.
Info: Will try to use device /dev/i2c-1 and address 0x49.
Info: WILL reset the device at the end.
Found Macronix flash chip "MX25L1605A/MX25L1606E" (2048 kB, SPI) on mstarddc_spi.
Reading old flash chip contents... done.
Erasing and writing flash chip... Erase/write done.
Verifying flash... FAILED at 0x00000000! Expected=0x02, Found=0xb0, failed byte count from 0x00000000-0x001fffff: 0xfe
Your flash chip is in an unknown state.
Please report this on IRC at chat.freenode.net (channel #flashrom) or
mail [email protected], thanks!
After that nothing happened when i tabbed the power button.
Luckily I could revert to my backup firmware, which made it work again.
Just now, I finally tried upgrading from my backup v1 to the v5, which turned out to work, so it\s only the v7 that is not working for my XL2720Z.
So thanks a lot for providing all the info in this thread.
Try using a different video card adapter and try again.
thanks alot that worked for me!davidm71 wrote:Just follow the tutorial on page 21.akhyg wrote:can someone update the tutorial for linux and upload links for xl2411z ? i got v1 now
Good luck.
i was able to update my 2nd XL2720Z to V008 (as the other one had this by default). tho i didnt really see what the difference between V7 and V8 is...
i'll leave it here so someone might find this useful:
"BenQ_XL2720Z_FW_V008_20160815_backup.7z"
https://drive.google.com/file/d/1ugWXkA ... sp=sharing
take care
