Motion Blur Reduction monitor buying suggestion?
refinedanarchy
Post by refinedanarchy » 09 Apr 2019, 19:34
After returning the horribly blurry Acer XFA240, I am deciding between the BenQ Zowie XL2411P ($250 new on Amazon and I can control the strobing using the utility by blur busters), the brand new LG 24GL600F-B (this one have '1ms motion blur reduction' but I am not sure about how customizable it is) and the last one is the Asus MG248QR (I am not sure about this either cuz most of the results I got from google is about the non 'R' version but it is refurbished for only $190 on Newegg). Basically the best bang for the buck option possible. I only play fps games like paladins, csgo, tf2 and other high performance games. One last thing, my system run at an avg of 120fps in all these games but a 1% low of 80fps. Oh and I don't give a crap about colors, I already have an IPS monitor that I'll use for watching videos. Or if you think any of these aren't good, please recommend any alternatives.
REMOV_CELER
Re: Motion Blur Reduction monitor buying suggestion?
Post by REMOV_CELER » 10 Apr 2019, 08:05
The modern LG blur reduction is not customizable afaik, on my LG 27GK750F (240Hz) it's just an on/off switch and you can do adjustments by adjusting the blanking intervals and/or settings like brightness and contrast. In my opinion the 27GK750F is one of the very few monitors that can (FINALLY!) match the motion clarity of a 150Hz fast phosphor CRT.. although that's a monitor entirely out of your budget, and wouldn't likely be too great for you, considering your in-game FPS.
refinedanarchy
Post by refinedanarchy » 10 Apr 2019, 10:18
well I think 144hz is enough and I plan to upgrade my pc in the next 2-3 years. I have a GTX 1050 Ti, the main bottleneck is the CPU. Unless going for 240hz is a worthwhile investment.
refinedanarchy
Post by refinedanarchy » 10 Apr 2019, 17:08
i have looked at that monitor and it's only $280 and I found one refurbished for $240, so more future proofing
REMOV_CELER
Post by REMOV_CELER » 11 Apr 2019, 02:54
Well if you can find the LG 27GK750F for $280, that's really great, since it's one of the few monitors that can strobe at 240Hz. I really love my 27GK750F, even without strobing, there's a frame-skipping bug atm but there's a work-around available, and it will likely be fixed in a firmware update.
refinedanarchy
Post by refinedanarchy » 11 Apr 2019, 07:14
the problem is that monitor lowest refresh rate for strobing is 120hz and I heard that it does have a lot of strobe crosstalk at that even with consistent fps. My pc can't reach no where close except games like Minecraft (which i rarely play)
refinedanarchy
Post by refinedanarchy » 11 Apr 2019, 10:09
I have decided to go with the acer xb241h, I found one for only $185 on ebay. The monitor can oc to 180hz, which is plenty. And ulmb is at 120hz, 100hz and 85hz
