Downsampling at 120hz?
DICKTracy
Post by DICKTracy » 18 Mar 2014, 14:03
Recently I have been doing some research into downsampling and while I think that I have been able to learn a lot on my own, I still have some questions that go on unanswered. I was hoping that someone here might be able to shed some light on the situation.
From my research I have learned that the GPU scales the image down to the screen resolution before sending it to the screen, which would lead me to believe that the frame data traveling down the cable to the monitor is unchanged whether downsampling is used or not.
If I am correct and this is in fact how it's being done, could this mean that I should still technically be able to get the max refresh rate of my monitor? Provided my computer could produce the frames fast enough?
Broken down:
render at 4k > take the 4 pixels that would make up the same area in 1080p > get the average of them so they can be displayed as one pixel > do this for all pixels > send downscaled image down the cable to the screen.
Is this how it works? or have I grossly over simplified the process?
Re: Downsampling at 120hz?
Post by Chief Blur Buster » 18 Mar 2014, 22:01
It depends on whether you are doing GPU scaling or display downscaling. I have seen it done both ways in the past.
If you are doing GPU scaling, and the GPU is fast enough, theoretically, you can technically use your display's maximum refresh rate.
However there's a factor: It is very dependent on the technique how you do the high resolutions to downsampling. When creating high resolutions via Custom Resolution Utilities for GPU downsampling, you are bottlenecked by the Pixel Clock. Your GPU's maximum pixel clock dictates the maximum number of pixels per second you can do, so the higher the resolution, the lower the maximum refresh rate. So downsampling via Custom Resolution Utility, can be problematic. Raising the dot clock limit via http://www.monitortests.com (Pixel Clock Patcher) may help in this situation.
Now, if you do another method of downsampling via driver AA method (e.g. Super Sampled AA methods such as OGSSAA, etc), if you find the right mode, then this does kind of essentially the same thing, doing internally 3840x2160 (even at 120Hz) and downsampling. This method is not capped by the dot clock limitation when attempting to downsample via a Custom Resolution Utility (e.g. NVIDIA "Create Custom Resolution").
Bottom Line: Depending on your graphics card, certain ultra-high-end AA modes does it in a visually or nearly visually identical way (based on my experience). Theoretically, proper variants of 2x2 SSAA is equivalent to downconverting 3840x2160 into 1920x1080. However, various AA modes does a lot of driver shortcuts and optimizations to attempt to speed things up at the cost of visual quality relative to downsampling via custom resolution. So it's sometimes crapshoot, but there are good posts on the Internet (e.g. http://forums.guru3d.com/showpost.php?p ... count=1201 ...) with good comparison screenshots.
trey31
Post by trey31 » 20 Mar 2014, 19:32
If you're interested in scaling the image on your PC and sending it out at max refresh there is another option as well: http://www.softth.net/. It's kind of like a software Eyefinity and it requires injection for DirectX programs, much like InjectSMAA or SweetFX do. However, it is not 100% compatible with everything, so read up on it first. You can use SoftTH with other injectors as well, like InjectSMAA, but there are some hoops you'll need to put your jumping shoes on for as they require different .dll files but have the same name so you'll have to rename one and then edit and re-direct the other .dll to the first .dll to get them to work together. Of course you could use RadeonPro for SMAA/FXAA/shader injection as well which in general is just much easier. But either way, there are options for everything and SoftTH is one of them.
If your preference is Image Quality before Refresh Rate though, you should try using actual resolution timings with some downsample resolutions to see what you prefer. In many cases a display can scale the image better than the GPU. On the Vizio M651d (1080p) I prefer playing 2560x1440 at 82hz with actual 1440p timings rather than with NVIDIA CP custom resolution of 2560x1440 "desktop" with 1080p timings at 103hz, unless its a competitive (snap reflex) FPS game. It scales much better on the panel with the actual 2560x1440 timing, even if it is only 81-82hz. On the other hand, 3840x2160 "desktop" with 1080p timings at 48hz is (by far) my preference over actual 4K timings at 37hz. 11hz doesn't seem like it would make a big difference in lag, but at refresh rates that low there is an easily noticeable difference between the two. With 3200x1800 its literally about a 50/50 split depending on the game and how much input lag comes into play. With something like Tomb Raider I'd play at 52hz with actual 3200x1800 timings, but Deus Ex: Human Revolution I'd play at 78hz with 1080p timings. On the Samsung UN55C7000 3600x2025 "desktop" at 60hz with 1080p timings were pretty sweet considering that panel wouldn't overclock to even 61hz without blurring like a Sims character taking a shower. The options on that panel were 1080p at 60hz or 3600x2025/1080p timings at 60hz so it was a pretty simple decision to choose your resolution on that one. Except for 3D Vision games, 1080p at 60hz Checkerboard with active 3D glasses was pretty epic...
As far as AA goes, Downsampling is typically the heaviest option to go with, which is why some are opposed to it. However there is a whole other side of the argument that many do not take into consideration and that is the difference in texture quality between a game being rendered in a higher resolution vs using an edge detect method of AA at a lower resolution. If you don't believe it, try this: Render a game capable of running a ridiculously high level of AA like 32x CSAA at 720p with the AA maxed out. Then turn the AA off in the same game and render it at 5120x2880 (16 x 720p, 4 x 1440p). If you liked that, try the same thing with an SMAA injector or FXAA with a mandatory LumaSharpen shader (then add an HDR shader and tweak RGB gamma settings and succumb to that which is SweetFX :lol: ). My point though is that AA isn't the only thing to consider when it comes to downsampling.
Of course the above example is more relevant with current/recent games than it is with older games. For instance there is a beneficial AA effect when using 3200x1800 in Star Wars: Republic Commando vs 1080p, but the texture quality argument is null in this instance. Even with the game's Ultra High textures there is no real difference as it was made to max out at 1600x1024 (if I recall correctly) and it has pretty low quality textures regardless of what the engine refers to them as (but in its defense it is pretty much the greatest Star Wars game ever made! ...well since Star Wars: TIE Fighter Collector's CD anyway).
Post by Chief Blur Buster » 20 Mar 2014, 21:16
Good reply, trey31!
