Another issue: Are you using multimonitor? Disable all monitors except the one displaying anime. Discordant-Hz multimonitor causes major framepacing problems, it's a Microsoft issue that Microsoft needs to fix eventually.blamore wrote:My display is 144, which is a perfect multiple of 24, not 30. So i dont see what that should matter. In fact, this 24fps anime does look better on 60Hz displays (with longer response time)
Videos (in particular anime) looks stuttery on my 144hz
Re: Videos (in particular anime) looks stuttery on my 144hz
So tried bakamplayer smplayer and mpv, but i dont see where I can enter that.RealNC wrote:"--video-sync=display-resample --interpolation" options and select a refresh rate that will force MPV to interpolate frames to reach the nearest FPS that fits exactly.
I tried entering it to bakamplayer command line and it said
[baka]: invalid command '--video-sync=display-resample --interpolation'
I tried with an without multimonitor, doesnt seem to be the cause of the problem.Chief Blur Buster wrote:Another issue: Are you using multimonitor? Disable all monitors except the one displaying anime. Discordant-Hz multimonitor causes major framepacing problems, it's a Microsoft issue that Microsoft needs to fix eventually.blamore wrote:My display is 144, which is a perfect multiple of 24, not 30. So i dont see what that should matter. In fact, this 24fps anime does look better on 60Hz displays (with longer response time)
In smplayer, open the preferences. In the "advanced" section (it's the last one), go to the "mplayer/mpv" tab. Enter these options in the "options" field. Without quotes.
If you want the highest quality filters too, then you can copy my options:
In Baka, I think you have to edit an ini file. It's probably easier to just use smplayer. I haven't looked up how to do this exactly in Baka.
MPV is tweakable to an absurd amount. There's a crapton of options, documented here:
https://mpv.io/manual/master
Code: Select all
--video-sync=display-resample --interpolation --profile=gpu-hq --blend-subtitles=video --scale=ewa_lanczossharp --dscale=mitchellMPV is tweakable to an absurd amount. There's a crapton of options, documented here:
RealNC wrote:In smplayer, open the preferences. In the "advanced" section (it's the last one), go to the "mplayer/mpv" tab. Enter these options in the "options" field. Without quotes.
In Baka, I think you have to edit an ini file. It's probably easier to just use smplayer. I haven't looked up how to do this exactly in Baka.Code: Select all
--video-sync=display-resample --interpolation --profile=gpu-hq -blend-subtitles=video --scale=ewa_lanczossharp --dscale=mitchell
Doesnt seem to have changed anything at all.
Works fine for me :-/
Wait, I had a typo in the options. A missing "-". Copy them again.
Also, make sure you switched your desktop to 60Hz. As said previously, 120Hz or 144Hz will not work.
No change at all. I had also tried "--video-sync=display-resample --interpolation"RealNC wrote:Wait, I had a typo in the options. A missing "-". Copy them again.
I dont think that options line is having any effect for me
Are you sure it's a 24FPS video you're trying to watch? Press Shift+i to display video information. It will list the video's FPS.
It is indeed 24. And my monitor is 120hz atm.RealNC wrote:Are you sure it's a 24FPS video you're trying to watch? Press Shift+i to display video information. It will list the video's FPS.
I downloaded mpv, added a video file to the folder and
Code: Select all
mkv --video-sync=display-resample --interpolation --profile=gpu-hq -blend-subtitles=video --scale=ewa_lanczossharp --dscale=mitchell --loop-file asd.mkvRe: Videos (in particular anime) looks stuttery on my 144hz
Maybe you made a mistake in smplayer and instead of "mpv" you have selected "mplayer?"
