Hello guys, messing up with CRU i got my integrated display to run easily at 90Hz
https://i.imgur.com/1R5ou3Z.png
But using this high refreh rate, its just like i can see some faint blac stripped pattern in some dark grey areas, is this because of front porch or something I can control or is just something that happens to some displays when pushed up higher?
Feeling like pushing a bit further, hehe still have some pixel clock remaining (240mhz max eDP)
proofs
https://imgur.com/a/FWq2Tjc
update: got it to 100hz but the faint lines still appear, but love the smoothness
Sucessfull overlocked ZBook 15 G1 1080p IPS eDP display 90Hz
kofapox
- RealNC
Re: Sucessfull overlocked ZBook 15 G1 1080p IPS eDP display
Have you tried automatic normal timings? Like "LCD Native" or "Reduced"?
kofapox
Here is the settings, using lcd reduced or normal i get black screen, but using the same timings from 60hz it works no problemRealNC wrote:Have you tried automatic normal timings? Like "LCD Native" or "Reduced"?
https://i.imgur.com/zELuk3V.png
the left setting on the image does not work, the right setting works.
the only problem is the screen faint horizontal black lines that sometimes when you look you can see, is strange, cant quite figure what it is, but boy its smooth.....
EDIT: the left setting is reduced blanking options for 90hz and the right setting is the same timings from 60hz but with 100hz refresh rate.
