BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
loopy750
Post by loopy750 » 30 Jul 2019, 03:26
hleV wrote:OOR Fixer updated to 1.3
Now accepts initial and setting delays as launch parameters.[/i]
Thanks, that has helped. In some rare cases it wasn't worked as expected, so an additional 500ms has fixed it. Something else that would be awesome if possible, the Windows power plan that puts the monitor to sleep after x minutes, when it awakes, it's out of range and OOR Fixer doesn't resolve this. I think that's about the only thing it's missing.
sosuyike
Post by sosuyike » 30 Jul 2019, 04:06
Happens on my side too, i just disabled the monitor sleep time (set to 0)
hleV
Post by hleV » 30 Jul 2019, 04:18
I'm aware of the sleep issue, and plan to look into it (among other things) when I have the time.
BenQ XL2546K @ 240Hz (DyAC+) • ROCCAT Kone Pro Air @ 1000Hz • HyperX Alloy Origins • CORSAIR MM350 PRO Premium • HyperX Cloud Revolver • NVIDIA GeForce RTX 3070 @ 2130MHz/8000MHz • Intel Core i7-8700K @ 4.8GHz • G.SKILL RipjawsV 16GB (2x8GB) 3000MHz CL15
Post by Chief Blur Buster » 30 Jul 2019, 16:15
I noticed that the computer often wakes faster than the monitor when exiting a hibernate/sleep/etc mode, so perhaps a much longer delay pecific to sleep-exits may be good.
sosuyike
Post by sosuyike » 31 Jul 2019, 09:03
Tip that may be included in the first post: You can and should still apply another ICC profile to improve the washed out colors
hleV
Post by hleV » 01 Aug 2019, 14:09
Post by Chief Blur Buster » 02 Aug 2019, 12:48
hleV wrote:OOR Buster
Thanks for adding the wake delay -- that probably will help!
jla_v
Post by jla_v » 05 Aug 2019, 16:50
Can this work with the 2420g in gsync mode?
senny22
Post by senny22 » 05 Aug 2019, 19:28
Hi! I'm really happy that this works but somewhat let down by the fact that I can't get over 180hz. Would a firmware update for my monitor potentially help? I have one of the oldest revisions of the XL2411Z.
hleV
Post by hleV » 05 Aug 2019, 23:53
senny22 wrote:Hi! I'm really happy that this works but somewhat let down by the fact that I can't get over 180hz. Would a firmware update for my monitor potentially help? I have one of the oldest revisions of the XL2411Z.
For what it's worth, I'm at XL2411Z V4 and while it's able to do 210Hz, eventually the screen will become white due to an unstable overclock. Same even at 185Hz. At 180Hz it's perfect.
