Blur Busters Forums
Acer Predator XN253QXbmiprzx
Postby kronos » 11 Jul 2019, 06:37
Hello, I'm new here. I was comparing some 240Hz monitors and I found this one here:
https://www.brack.ch/acer-monitor-predator-xn253qxbmiprzx-919982
0.3ms!
Anyone tested it?
kronos
Re: Acer Predator XN253QXbmiprzx
Postby do0om » 11 Jul 2019, 11:01
Review is pending here : https://twitter.com/pcmonitors/status/1 ... 5392016388
for the freesync version : https://twitter.com/TFTCentral/status/1 ... 7399746560
You just have to wait a bit :D
do0om
Postby kronos » 09 Aug 2019, 11:45
Here it is:
Box said 0.4ms
don't know if its the new .09-TN-panel
the cables included - just videoport/usb/power
Aside AG352QCX
kronos
Postby whitepuzzle » 11 Aug 2019, 18:59
kronos wrote:Here it is:
Box said 0.4ms
Aside AG352QCX
How is colour temp and gamma, subjectively? Once set to the best OSD mode, of course.
whitepuzzle
Postby Mangemongen » 15 Aug 2019, 18:00
At how high a hz can this monitor do strobing?
Mangemongen
Postby zerocool » 16 Aug 2019, 02:40
I want to buy this monitor if it's using the new generation of 0.5ms 240hz panel. I've been waiting a long time for Asus or Acer to release a proper one with actual GSYNC at 24.5" screen size. I'm hoping this will be a true successor to the Acer XB252Q/Asus PG258Q screens with straight up faster response times across the board, if so it's a buy for me.
It would be awesome if its response times were basically the same as its sister the recently released Acer XF252Q.
On that note, does anyone actually know with 100% accuracy that this screen is indeed using the new panel type or is it just a refresh of the old panel?
Thank you!
zerocool
Postby Konatsuz » 16 Sep 2019, 12:13
zerocool wrote:I want to buy this monitor if it's using the new generation of 0.5ms 240hz panel. I've been waiting a long time for Asus or Acer to release a proper one with actual GSYNC at 24.5" screen size. I'm hoping this will be a true successor to the Acer XB252Q/Asus PG258Q screens with straight up faster response times across the board, if so it's a buy for me.
Thank you!
It is the new AUO panel.
Konatsuz
Postby frunction » 03 Oct 2019, 13:38
Thank you!
This is the XB252Q:
http://www.panelook.com/M250HTN01.3_...iew_28334.html
And the XN253QX:
http://www.panelook.com/M250HTN01.9_...iew_39919.html
There is a difference in pixel response, with the XB252Q and other similar models such as the PG258Q being 3.8ms typical, while the newer panel is 2.4ms typical. So these newer models are almost 40% faster in pixel response. This jives with what tftcentral recorded for the XF252Q being 2.6ms. I did a side by side and you can see some improvement with slightly less trails in UFO test.
Now the other difference, the new panel shows "Antiglare (Haze 25%)" for the surface, whereas the old panel does not have this haze. I assume this is what I am disliking about the look of this monitor, looks kind of grainy due to this coating.
frunction
Postby BlurBoss » 05 Oct 2019, 07:48
Do you guys think that there might be an advantage of going for 144 Hz version of this monitor instead of 240 Hz? Would 144 Hz provide less strobe cross talk at 144 FPS? viewtopic.php?f=2&t=5823
BenQ XL2546, i9-9900K @ 5.0 GHz, RTX 2080 Ti, 32GB (2 x 16GB) 3200 MHz CL14 RAM, Asrock Z390 Phantom Gaming-ITX/ac.
BlurBoss
Return to News / Rumors / Conventions
Who is online
Users browsing this forum: No registered users and 0 guests
