CRT and Stuttering - False memories?
Jason38
Re: CRT and Stuttering - False memories?
Post by Jason38 » 19 Aug 2019, 19:07
Chief Blur Buster wrote:
Jason38 wrote:It was interesting I was at a garage sale and someone was giving away a NEC CRT so I took it. I tried to hook it up to a Windows 10 machine and thought I was going to die from the flicker. 5 minutes made me feel terrible. It's strange though because when I hook my Sony Wega KV-20FS120 and play N64 it doesn't feel terrible like the NEC hooked up to Windows 10.
That's to be expected especially if you used it in a TV room style manner.
(brightness was set to a comfortable level, you used a room with sufficient lighting, etc)
Jason38 wrote:Makes me wonder if I would get a different result with Windows XP and older hardware?
Nope. Same problem happens to other people.
The explanation is simple. My elementary, it is very simple in Sherlock Holmes terms. The reasons are mutlifold:
(1) Brightness of Windows themes. Windows has a lot of white-colored windows. Bright = harsh.
(2) Loss of acclimation. One is no longer used to it.
(3) Default refresh rate of Windows 10 is automatically 60Hz.
(4) Viewing distance to a CRT. Viewing too close to 60Hz.
You must use NVIDIA Control Panel, AMD Catalyst Control Center, or ToastyX CRU to properly configure a higher Hz such as 85Hz. It partially compensates for the factors above, and back in the day, 75Hz, 85Hz options were easily available, but is configured through a different mechanism today than it was yesterday. Did you raise refresh rate from the default 60 Hz setting?
I've heard of this over and over enough and it just essentially boils down to (1)/(2)/(3)/(4) and similar factors.
Jason38 wrote:I can't notice the motion blur with the LG ultragear and this is something that almost always bothers me and causes me eyestrain. I play Sonic on it and can't notice it causing me any strain.
Use a higher refresh rate when using PC games, but stick to games that allow framerate = Hz.
Too low Hz = too much flicker
Too high Hz = too hard for framerate to match Hz
Find your goldilocks Hz. I recommend at least 100Hz for impulse-driven viewed displays viewed at computer-viewing distances.
We're familiar with this at Blur Busters...
This is an awesome answer thanks. I will try messing with it again on the weekend because I love the quality of CRT. I thought it was windows 10 because I couldn't change the refresh rate but didn't think about changing it with the control center. It's strange because my LED monitor lets me do it with windows 10 but CRT wouldn't go above 60hz.
Post by Chief Blur Buster » 19 Aug 2019, 22:36
That's because of the EDID / DisplayID system that transmits Plug-n-Play information between the display and computer.
Most old CRTs did not have this, and Windows 10 does not unlock >60Hz by default.
Make sure you don't exceed the specs of your CRT -- horizontal scanrate and refresh rate. Make sure you check the rear of the CRT for the scanrate ranges, and keep within that with Custom Resolution Utility. Use the old blanking interval feature (CRT sized), not the CVT-Reduced (designed for digital displays) -- CRTs can't handle reduced blanking intervals.
Jason38
Post by Jason38 » 20 Aug 2019, 10:19
Chief Blur Buster wrote:That's because of the EDID / DisplayID system that transmits Plug-n-Play information between the display and computer.
I was able to set the CRT to 100hz refresh rate. I having a timing option I can play with CVT, CVT reduced blanking(Didn't use this), GTF, DMT and manual. It was set to manual and I switched it to CVT. Not sure if it's the best option. I read somewhere else on your forum this is an old feature for CRT as a guard delay. I still prefer the LED for computer use(reading web pages) but you are totally right if I distance myself away from it gaming on it is good. Thanks again for the suggestions.
rasmas
Post by rasmas » 20 Aug 2019, 10:31
I'm interested on this thread because i'm using a CRT right now because i could not get used to the LG Ultragear 24GL600F-B myself (i wonder if i got a faulty unit), and i'm trying to find good CRTs, because the one i'm using is blurry on text, does not allow me to see too good to distant enemies, flickers,i sometimes see double images too,... but still, i guess because of motion blur, i like it more than the others TFTs i've tried.
Well, as i'm using a CRT connected by VGA to my (a bit old) GPU, i tried to see some youtube videos of Diablo 2, and i see them good enough and i cannot notice double images on these videos, could you try a video to see if it happens to you there too? Maybe videos, as have stable frames, are not affected?
Keep in mind i have no idea and i don't know (and often i don't easily understand :D ) a lot of things :P .
Chief Blur Buster wrote:...
I had no idea about that, Thanks!
Although not sure if my monitor (Mitsubishi Diamond Plus 73) supports more than the 1280x1024 60Hz i have now, because, yes, it shows higher resolution and refresh rate but i saw some specifications online that seems that to get higher Hz i must set lower resolution, and the higher resolution does not fit my aspect ratio (and i didn't see it supported on these specifications).
Anyway it is a very useful info in case i can find better CRTs.
Jason38
Post by Jason38 » 20 Aug 2019, 10:44
Does every LED monitor cause you strain?
Post by Chief Blur Buster » 20 Aug 2019, 17:50
You can use any aspect ratio. CRTs do not care. 1920x1080, 1423x761 or whatever. You can use the analog vertical picture resize knob to make the aspect ratio correct.
You can also remove vertical resolution without removing horizontal, e.g. 1280x900 in order to get enough bandwidth to raise refresh rate from 100Hz to 120Hz.
Even, 3000x900 and 1000x900 behaves the same on a CRT. The only thing that changes is horizontal resolution and how horizontally compressed the Windows desktop becomes at default picture aspect ratio.
Focus on the scanrate specs, and vertical resolution specs -- the horizontal resolution is arbitrary for sake of convenience. Just make sure that the blanking intervals scale properly. e.g. doubling horizontal resolution requires you to double the horizontal blanking interval numbers.
Just don't exceed horizontal scanrate limit and don't exceed vertical scanrate limit. And don't make those blanking intervals too small.
Jason38
Post by Jason38 » 20 Aug 2019, 21:53
Chief Blur Buster wrote:You can use any aspect ratio. CRTs do not care. 1920x1080, 1423x761 or whatever. You can use the analog vertical picture resize knob to make the aspect ratio correct.
This is gold! Thanks I have so much to learn about screens! My resolution was at 1024 X 768 going to change it and raise it to 120hz.
rasmas
Post by rasmas » 21 Aug 2019, 08:57
Jason38 wrote:Does every LED monitor cause you strain?
Well, i've tried 5 by now and i feel (at least) they are not better than this (not good) CRT... On the other hand i have been using a TFT for years until it broke but while i've been using it i have been having eye strain and sometimes motion sickness, something i never had before getting the TFT. Allways thought it was just me but after trying this CRT while looking for a new TFT i even felt that i got my eyes better :) .
I know i can get used to TFTs, but not sure if i want to xD .
Very interesting, didn't thought about it, although (in my case) i think i'll get a bit too small screen. But still very interesting.
Chief Blur Buster wrote:You can also remove vertical resolution without removing horizontal, e.g. 1280x900 in order to get enough bandwidth to raise refresh rate from 100Hz to 120Hz.
I admit i'll have to read this several times because i don't understand many concepts xD . But you know a lot of this ;) .
2mg
Post by 2mg » 19 Jun 2026, 20:30
I have to necro this post, don't torch and pitchfork me please.
masneb wrote: ↑
19 Aug 2019, 19:03
I didn't misunderstand you, I specifically stated that you shouldn't cap your FPS unless there is a very specific reason for doing so as it leads to a lot of other anomalous behavior, especially at very low CPU utilization levels and I also mentioned is due to extreme amounts of patching over the years especially on dependencies you can't test something like this and have it be the same as when you first played the games as the games you're playing not only are not made for hardware you're remotely playing on, but also that their software dependencies can be completely changed over the years.
That's why I mentioned, when people do stuff like this they test it on old hardware and old builds of software from back when these games came out or they run into all sorts of weird bugs.
Yes, 60hz is hard on your eyes (just like ULMB). Some monitors are worse then others. That wasn't just specifically relating to CRTs, but also the coating on the monitor and the brightness of the monitor itself.
19 Aug 2019, 15:30
No, they did not.
Are you playing Diablo natively or through virtualization? Make sure to play natively, since emulators & other virtualization can add stutter that was not there before. For example, sometimes 70Hz VGA was emulated at 60Hz, so you got VGA stutter even with emulated framerate=Hz. Eliminate those stutter weak links and make sure your emulator is stutterless at the video mode you plan to run your game at. Then you only have the game's native stutter.
Also, there's an additional psychological factor: It's a case of getting used to something.
-- Just like when we switch from 60Hz to 144Hz, some people now find it unbearable to switch back to 60Hz.
-- Likewise, people were used to CRT stutter, and then got used to LCD blur hiding stutters, then switching back makes it look unbearable.
So there may be an element of 'false memory' but it's grounded simply in getting used to something better (in certain ways). LCDs were worse in motion blur, but were better in hiding stutters. We just got used to that.
What none of you, well Chief did a bit with "we were used to it", answered to OP is how come we weren't appalled with FPS<Hz on CRTs.
Sure, the "we were younger, we didn't care, we didn't know better, we thought that's the way it is, etc" holds some water - just like we were using RF or Composite to play console stuff on TVs even tho better options were available, or were becoming available as time went on.
OP also isn't using 30FPS@60Hz for dumb reasons, a lot of people simply didn't have the GPU horsepower to reach even 60FPS in that wild west era, so now he is trying to emulate underpowered hardware by using limiters to simulate old hardware in case of HL1, and in case of Diablo 2, that game was indeed 25FPS in singleplayer, in multiplayer it upped the FPS but animations were still 25FPS.
Another key here is that OP didn't state if he was using Vsync - afaik when FPS<Hz on a CRT/strobed display and there is no Vsync, could the tearing actually reduce the visibility double-image artifacts?
Supermodel_Evelynn
Post by Supermodel_Evelynn » 27 Jun 2026, 13:15
One thing to note is that a Super Nintendo running on a CRT TV will always give a superior experience than emulation via PC.
Emulation via PC can introduce all sorts of nasty judder and other issues unless configured properly and can vary between PCs and Displays.
Consoles being closed source and having strict development requirements and amazing compatibility made enjoying games back in the 90's a perfect experience as opposed to emulating it today.
