AMA menu on Benq GL2760H only shows off and on.
maou42
Post by maou42 » 01 Sep 2019, 04:18
Hi
As stated in the subject, my monitor only offer OFF and ON as AMA options, not OFF HIGH and Premium as on all my previous Benq monitors with AMA.
Is that normal or is my monitor not functioning properly?
Thanks
Re: AMA menu on Benq GL2760H only shows off and on.
Post by Chief Blur Buster » 02 Sep 2019, 21:14
I think that it's a model-specific quirk. Some models have multiple overdrive settings, and some models have fewer overdrive settings.
Ideally, I wish manufacturers would make Overdrive a slider adjustment (just like Brightness or Contrast) with a range of 0%...100%. Since most of them manipulate a hidden overdrive gain register that actually has 100 different overdrive settings or 128 overdrive settings or even 256 overdrive settings! This would provide way more flexibility for more users, especially since even panel temperature and other factors can cause minor shifts in overdrive results that would be solved by a minor adjustments of Overdrive Gain.
maou42
Post by maou42 » 02 Sep 2019, 23:21
Many thanks for your reply.
I wish the setting on my monitor did not go from Psychedelic trip motion blur when AMA is off to inverse ghosting when ON.
