AOC AG251FZ Stuttering Problem.
perling
Post by perling » 30 Nov 2019, 17:50
Hello There ,
I have this Monitor with 240hz in Apex Legends i got stange Stuttering when the fps drops below 190-210
If i make a fps limit 180fps and dont get any Stuttering is this normal?
If i make a fps limit to 190fps i got stuttering everytime.
I dont have Activate Freesync , i want the Low Input Lag to use and this works only without Freesync.
180fps Limit and all is fine but 240fps Limit and i get drops between 190-210 i get the stutter and with 220-240fps its fine
I hope you can understand my english.
Best Regards Perling
Re: AOC AG251FZ Stuttering Problem.
Post by RealNC » 01 Dec 2019, 03:01
It's normal. This is the reason freesync exists, to reduce stutter when FPS is not equal to Hz.
perling
Post by perling » 01 Dec 2019, 05:25
but why i dont have any stutter when i limit the 180fps? it can drop to 140 and its run smooth and if i limit to 190fps i got everytime stutter.
i dont get stutter under 180fps i get only stuttering 190 - 210fps
my english is so bad sry
