XL2411Z owners - how's the backlight bleed?
Oofloom
Post by Oofloom » 02 Apr 2014, 21:48
I've been wondering how it compares to the XL2420Z, which had no noticeable bleed whatsoever in pcmonitor.info's review.
Falkentyne
Re: XL2411Z owners - how's the backlight bleed?
Post by Falkentyne » 02 Apr 2014, 22:17
Virtually none on my 2720Z.
Keep in mind that backlight bleed is usually caused by warped frames/bezels/mounting errors, etc. Many times, if you've ever disassembled a panel before and are comfortable with the procedure, you can improve bleed by removing the frame, fixing any bends, and remounting.
dippadui
Post by dippadui » 02 Apr 2014, 22:54
this is mine xl2411z
20140403_064209 (800x600).jpg (170.94 KiB) Viewed 11594 times
Oofloom
Post by Oofloom » 03 Apr 2014, 02:43
Falkentyne wrote:Virtually none on my 2720Z.
That's one of my concerns with the XL2411Z compared to the XL2420Z. The 11Z's build quality doesn't look as good as the 20Z's. I move my main monitor around a lot, so that could cause problems if the 11Z flexes too easily.
masterotaku
Post by masterotaku » 03 Apr 2014, 03:30
The top left corner of my XL2411Z is darker. This image of the XL2420Z review resembles it well:
Strange fact: If I try it with red, green, and blue screens, it can only be seen on the green screen. The other ones look uniform.
I'll post pictures later in the day (6-7 hours from now).
Monitor: Asus PG278QR
dippadui
Post by dippadui » 03 Apr 2014, 11:17
is the backlight bleed fixable?
masterotaku
Post by masterotaku » 03 Apr 2014, 11:26
Sorry for the double post. Here are the pictures I promised:
White screen.
Red screen.
Blue screen.
Green screen.
Bonus: green screen at night.
dippadui
Post by dippadui » 03 Apr 2014, 12:06
i will too take more pictures with better camera when it comes dark 2-3 h from now.
Oofloom
Post by Oofloom » 03 Apr 2014, 12:54
Good pics, man. Could you do a black screen pic too?
masterotaku
Post by masterotaku » 03 Apr 2014, 13:37
Oofloom wrote:Good pics, man. Could you do a black screen pic too?
Sure. These are four pictures made in the dark. The black level changes a lot depending on the frequency. My firmware is still V1.
120Hz with Lightboost at 10%.
120Hz with motion blur reduction (it looks the same as the previous one :lol: ).
60Hz with MBR (brightness is the same as 120Hz, because of the double strobe).
85Hz with MBR (that black bar in the center is because the camera noticed the flickering. In real life it looks like the 60Hz pic).
