Hello,
I just got a 144hz MSI MAG241CV Freesync monitor (G-Sync compatible) but it doesn't seem like G-Sync is working properly.
The monitor is connected to a GTX 1070 OC with 1.2 DP cable.
So I have enabled Freesync in the monitor OSD, performed a driver clean with DDU, then installed latest nvidia driver and set recommended settings:
Set up Gsync => Enable for full screen mode
Manage 3D settings => Highest available Refresh Rate, G-Sync Monitor Technology, Vsync ON, Low-Latency mode to ON, Limiter set to 141 fps (if in-game limiter is not available)
And finally enabled the G-Sync indicator.
I've tried in several games (Rocket League, RDR2, GTFO) but the G-Sync indicator won't show up and my monitor frequency stays at 144hz even when FPS <140.
Also downloaded the G-Sync Pendulum test app but it doesn't let me select G-Sync (it auto unticks right when I tick the box).
What did I do wrong?
edit: I managed to enable G-Sync by installing an older Nvidia driver, seems like any drivers after 441.66 will prevent g-sync to work with this monitor..
G-Sync not working
NeanderTHALL
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — BFI / ULMB / ELMB / DyAc / framegen / LSS / etc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory: Display Science Section
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
