couple questions about freesync
fowteen
Re: couple questions about freesync
Post by fowteen » 21 Mar 2020, 14:41
so just to confirm, if a monitor supports lfc then it is automatically on and you don't have to turn it on through monitor/gpu settings?
Post by jorimt » 21 Mar 2020, 17:22
fowteen wrote: ↑
21 Mar 2020, 14:41
Correct.
Displays: ASUS P27UCWM, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
fowteen
Post by fowteen » 29 Mar 2020, 17:50
I recently wanted to try playing csgo with freesync and vsync on and the -3 fps cap but csgo has two different types of vsync. double and triple buffered. I do not know in depth what vsync is apart from it caps fps to your monitors refresh rate and only displays frames when they are needed so does one of the (double/triple buffered) vsync modes work better with the recommended no tear,smooth frametime experience than the other?
Post by jorimt » 29 Mar 2020, 20:14
fowteen wrote: ↑
29 Mar 2020, 17:50
Both G-SYNC and FreeSync function on a double buffer.
pc2000
Post by pc2000 » 19 May 2020, 16:06
And since G-SYNC + V-SYNC “On” only holds onto the affected frames for whatever time it takes the previous frame to complete its display, virtually no input lag is added; the only input lag advantage G-SYNC + V-SYNC “Off” has over G-SYNC + V-SYNC “On” is literally the tearing seen, nothing more.
Is it still virtually no input lag if frames are exceed the sync range? I saw the guide image: vsync 2-6 frame delay if exceed g sync range.
Post by Chief Blur Buster » 20 May 2020, 16:45
pc2000 wrote: ↑
19 May 2020, 16:06
It depends on what fallback sync technology you use for frame rates that hits the top end of VRR range.
If you configure VSYNC ON for the backup sync technology, it will generally have the same lag of VSYNC ON.
So you want a frame rate cap to keep your framerate within VRR range. Or use GSYNC+VSYNC OFF.
