Are there any advantages of gsync on + vsync off over gsync on + vsync on??
with -3 fps cap in both scenarios
Re: Are there any advantages of gsync on + vsync off over gsync on + vsync on??
Displays: ASUS PG27AQN, LG 48C4 VR: Beyond, Quest 3, Reverb G2, Index OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboards: Wooting 60HE, Logitech G915 TKL Mice: Razer Viper Mini SE, Razer Viper 8kHz Sound: Creative Sound Blaster Katana V2 (speakers/amp/DAC), AFUL Performer 8 (IEMs)
okay thanks that's what I thought. I was just making sure I understood this correctly.
Yeah, at the same framerate within the refresh rate, G-SYNC + V-SYNC off and standalone V-SYNC off have up to 1/2 frame (so anywhere from 0 to 1/2 frame) advantage in input lag at any given point when compared to G-SYNC + V-SYNC on. This is exhibited as tearing; whenever you see the tear, you're seeing you're literal (and only) input lag reduction over G-SYNC + V-SYNC on.
wait what do you mean by gsync+vsync off and standalone vsync off
- G-SYNC + V-SYNC on = G-SYNC ON + V-SYNC ON
- G-SYNC + V-SYNC off = G-SYNC ON + V-SYNC OFF
- standalone V-SYNC off = G-SYNC OFF + V-SYNC OFF
so gsync+vsync off's advantages over both on is only less input lag?
Tearing. When you're asking for less input lag in this case, you're asking for tearing. There is no other difference but that between G-SYNC on + V-SYNC off and G-SYNC on + V-SYNC on inside the refresh rate.
but you said gsync+vsync off has an advantage in input lag over gsync+vsync on
The input lag advantage is TEARING
![Laughing :lol:](./images/smilies/icon_lol.gif)
![Image](https://blurbusters.com/wp-content/uploads/2017/06/blur-busters-gsync-101-middle-screen-vs-first-reaction-measurements.png)
G-SYNC + V-SYNC is the fastest a single frame can be displayed tear-free; for any faster delivery, it has to tear (aka G-SYNC on + V-SYNC off or G-SYNC off + V-SYNC off). That is your only input lag "advantage" over G-SYNC + V-SYNC: tearing.
