Yes. Create a custom resolution of 1440x1080. See if you can do the VT1350 or VT1500 trick. Then use that resolution. It will be better than 1280x960, because there will be a 1:1 pixel mapping.lebowsky wrote:hi, tried the 1350/120hz, very nice picture and performance. my problem is, I play cs:go in 1280x960 4:3 stretched, so I need to force the stretch to fullscreen in the nvidia control panel. the dilemma, with 1350/120 I have a 4:3 screen with black bars in go and for scaling I need to choose a non-custom resolution. Any suggestions?
Optimal Strobe Utility Settings at 120Hz
- masterotaku
Re: Optimal Strobe Utility Settings at 120Hz
Monitor: Asus PG278QR
ha, sometimes things are so easy, thanks
- masterotaku
You're welcome. By the way, I've just seen The Big Lebowski half an hour ago for the first time. Great coincidence, and great movielebowsky wrote:ha, sometimes things are so easy, thanks
"Yeah, well. The Dude abides."
is it normal, that the monitor information shows "@60Hz", when using custom resolutions with 120Hz?
- masterotaku
It happens to me as well with all custom resolutions I've created. Right now, I'm using 90Hz and the monitor is reporting 60Hz. But it doesn't matter because the monitor works perfectly.lebowsky wrote:is it normal, that the monitor information shows "@60Hz", when using custom resolutions with 120Hz?
If you want to know at what Hz the monitor is when you are playing (i.e: if you notice the monitor changes frequency but you don't know which it's using), you can use a fps counter program, like FRAPS or MSI Afterburner, and vsync. When your fps are perfectly synchronized and capped, then that's the frequency you're using.
