Best settings on Benq 2420z?
PUNCHRULLE
I have tried alot but cant really get the perfect colors/brightness etc.
Anyone found any good ones? im not using blur reductinon atm
Re: Best settings on Benq 2420z?
Currently, the easiest way to get much better colors is to install the .icc profile file for the XL2420Z. It makes colors much better.
PUNCHRULLE
Yeah i installed the display pilot if that is what u are meaning,im using movie preset, decent colours
if you can afford it buy a colorimeter like the x-rite i1pro display... if really you wanted so...
Yes, a colorimeter helps.
You can also install the .icc file that's available for the XL2420Z to give its colors a good jumpstart.
Where can I find this .icc profile?Chief Blur Buster wrote:Yes, a colorimeter helps.
PUNCHRULLE
Its on the cd that came with the monitorKnxwledge wrote:Where can I find this .icc profile?Chief Blur Buster wrote:Yes, a colorimeter helps.
Ahh thats a bummer. I don't have a cd drive on my computer lolPUNCHRULLE wrote:Its on the cd that came with the monitorKnxwledge wrote:Where can I find this .icc profile?Chief Blur Buster wrote:Yes, a colorimeter helps.
Calibrate your monitor here http://www.lagom.nl/lcd-test, at least the result would be as good as the icc profile included (better actually).
It's usually a gamma correction to be done, most of gaming preset are unrealisticly vivid or washed out.
The .icc files can be downloaded in pcmonitor's review: http://pcmonitors.info/reviews/benq-xl2420zKnxwledge wrote:Ahh thats a bummer. I don't have a cd drive on my computer lol
