There are half a dozen PCs in this location, but my primary gaming system is the one posted in Desk Setup Thread, but the tweet shows a hint of my cable routing: Spring Cleaning of the main Blur Busters Computer on Twitter.disq wrote: ↑30 May 2020, 14:58Chief, maybe you have some photos of your setup or setups that you consider that are following your thoughts you expressed in above comment? I would be very interested too see those.
Or maybe the other members participating in this thread could also post their setups so others could give their opinions and hopefully get better at some aspect that until now they thought it was fine to have it that way. I think it would be beneficial to everyone, to have a base we could look at, as a picture helps a lot in this context.
PS: My English is not perfect, but hopefully you can understand what i'm trying to say here.
Slightly aging now, but goodie at the moment as it's all-cores 5GHz stable! Some cases, such as the Inwin 303, has a way to allow you route power cables directly away from motherboard then go behind a metal shield under the motherboard. So unshielded high power wires aren't hovering millimeters away from important chips nor data cables, and there's almost no data cables thanks to the legacy-free design despite now being a 3-year-old computer.
An off-the-shelf watercooler purrs along -- I can't confirm this and never thought about it back at the time -- but I'm deducing it probably produces a better computer-internals RFI environment by keeping fan motors away from the motherboard -- probably helping prevent RFI-induced crashes during overclocks (from cheaply-made crappy fan motors millimeters away from a CPU) since computers are probably more sensitive to RFI-induced slowdowns/crashes during overclocking due to tighter error-correcting margins. Who knows? Anyway, it's 5Ghz allcores-stable. It's also an 80PLUS Platinum power supply too, those are usually RFI-cleaner too. It's scientifically logical to pay attention to RFI hygeine when building a computer, in a "just in case" manner -- doesn't hurt.
While a very inexpensive case, it's very lovely as a 100% legacy free system with zero optical drives and zero drive bays (except hidden under the motherboard). So there's few data cables at all, and there's just only M.2 drives. Being made in 2017, this is the intel i7740 (everyday OC 5GHz), getting old but few chips outperform in older games.
The rules of squares is your friend when routing power wires around the internals of a computer case. Wires 50 millimeters away from surface of motherboard is superior to wires only 10 millimeters away from the surface of a motherboard (EMI injection factor). Now, wires on opposite side of a metal shield separator is even superior (e.g. routing wires on the opposite side of a steel plate under the motherboard, creates a Faraday Cage effect there that is just as good as larger distances between wires) -- so you can favour a computer case that lets you route wires under the motherboard on the opposite side of a steel plate. Hits two birds with one stone; looks prettier for cable routing, and also cleaner EMI hygeine.
I'm no fan of ziptieing between SATA cables and power wires (Especially the wire for the GPU power connector); that is not good RFI hygeine: High-bandwidth data wires AWAY from high-current power wires where possible -- if you studied electronics in school, you'll be very familiar with that concept in electronics circuit design. But duh....what SATA wires? I have none!
(I have drive bays under the steel plate, if I wish, but with three M.2 slots, why do I need drive bays? And I have a parked-away DVD-RW which I only use once every few months)
So you see the Blur Busters main gaming computer is a legacy-free K.I.S.S. of fast + simplicity, and it really simplified cable routing. I didn't spend too many hours on this, except to add the UFO customization and change the RGB to "TestUFO colors". Great "wow-per-hours-of-build" factor for busy Chief Blur Buster -- many forum members spend more time building custom systems though.
Anyway, it's a happy accident of good EMI/RFI hygeine when this computer was built, probably helped it be stable at 5GHz all-cores at default voltage, too. Mind you, so many problems can happen, e.g. loose card in PCI slot, to just bad CPU lottery, or corrupt software install. That said, I never bothered to troubleshoot EMI/RFI, I just simply made sure of good hygeine, just like "washing your hands just in case".
A new tower needs to be done (i9? Threadripper? Etc. Mulling options.), and turn this into a hand-me-down system, but I needed to get a Razer Blade laptop (240Hz RTX 2080) for travel because I need to do mobile TestUFO PowerPoint-style presentations (and it was amazing at CES 2020)....and then COVID hit. Now I almost regret not getting another tower instead in these stay-at-home times. Doh!
Keep safe!
