Locked
kofman13
Post by kofman13 » 02 Jul 2020, 08:18
Love the performance of my XB273X (aside from glow and bleed..) but curious to try a 25 inch monitor as well, should i get MAG251RX, VG259QM, or XB253Q GX?
fowteen
Post by fowteen » 02 Jul 2020, 12:42
thaleskbulozo wrote:
30 Jun 2020, 18:54
I was analyzing the "ASUS ROG Swift PG258Q Game Monitor G-SYNC 24.5" Full HD 240Hz 1080p 1ms "but I believe it is outdated.
How should I choose my monitor?
* Native G-sync, or Compatible with G-sync?
Which of the two technologies will be better in a range of 130 to 240Hz?
Getting a native gsync monitor and using gsync will give you a really good experience at those ranges since the variable overdrive will help minimize (get rid off?) pixel overshoot however a lot of people don't even notice it at those ranges, personally on my monitor (without native gsync) I only notice pixel overshoot at around 60-80 fps.
invict
Post by invict » 02 Jul 2020, 17:38
Greetings everyone
@RLCScontender
I hope you can help me with this one, i have been using XL2720Z for the past years, and altough it served me well in regards of gaming, it was, and still is lackluster in colors, which is expected considering it is a TN panel.
I will sell this monitor to a friend and i need a substitute, i mainly play Warzone and sometimes League of legends,BF1,and cs go iam really competitive, but not to the point to spent plenty of hours daily training to achieve ranks, or go pro :).
The problem is simple, i cannot decide which monitor to buy altough iam inclined to these models:
->LG GL-27850B -> Contrast levels concern me(i play mostly at night), no blur reduction tecnology,
->ASUS VG27-AQ -> 165hz 1440p, ELMB,
->MAG251rx ->240hz, good motion clarity (but only at those refresh speeds?), the stand is horrid tough.
The only thing that really interest me on going for a 1080p monitor is the ability to maintain high framerates, pair that with ips tecnology, and achieve great motion clarity and great color reproduction. My concern is simple, MY 1080 ti +oced 8700k cannot obtain 240hz reliably on the game i play the most, (warzone), and i think it will hinder the performance to the point iam not sure if going for 144z 1440p is a better option( which i can reliably play at 100 to 150 fps).
The fps i get in warzone are between 125 and 170, and at these fps, is there any fast ips 240hz monitor which can be much better on motion handling than my XL2720Z @ 144HZ, or a 144hz 1440p nano ips?
Thanks in advance!
thaleskbulozo
Post by thaleskbulozo » 02 Jul 2020, 19:28
fowteen wrote:
02 Jul 2020, 12:42
30 Jun 2020, 18:54
So are you able to play above 100fps without experiencing slowness or ghosting in the image? Well this is my doubt, what is your monitor model? ...
fowteen
Post by fowteen » 02 Jul 2020, 20:18
02 Jul 2020, 19:28
fowteen wrote:
02 Jul 2020, 12:42
30 Jun 2020, 18:54
I have the omen x 25f and only notice overshoot really bad when fps goes under 80 above that I can't see it but like I said I think I saw chief say that some people are more sensitive to it than others and I think it also matters with what game you play.
RLCSContender*
Post by RLCSContender* » 02 Jul 2020, 22:09
invict wrote:
02 Jul 2020, 17:38
Greetings everyone
@RLCScontender
Thanks in advance!
The frame rate you are getting doesn't really matter for the acer predator xb273x because of variable overdrive. Based on my findings, The g2g response times are consistent along ALL of the refresh rate range. At 240hz, there's only 3-4 TN (aw2518hf, omen x25f, nitro xv252q, xn253q) that exist today that has a slightly better g2g response times based off my oscilloscope test results. , and we are talking UNDER 0.4ms. Not that matter because when it comes to the input lag i measured, it will kill those TN in a 1 vs 1 scenario. The only monitor that can stand a chance against the g sync 240hz 27" predator is the vg259qm/vg279qm only IF the framerate is above 240hz. If the framerate is 240hz or below, it will also beat those 280hz monitors.
And u dont' really need a professional reviewer to tell you. Blurbusters UFO tests generally don't lie. It even puts the all mighty MSI MAG251RX to shame. Click on this image to see how much better the clarity is on the predator xb273x vs the xb253qgx and the msi mag251rx. yes, these are PERFECT straight line UFO tests.
RLCSContender*
Post by RLCSContender* » 02 Jul 2020, 22:25
kofman13 wrote:
02 Jul 2020, 08:18
You could... but expect a huge dip in g2g response times and input lag. However, there's less eye tracking involved. If you are in the market for a 24.5" monitor, the alienware or the msi are excellent choices. The vg259qm is alaso an excellent choice if you are playiing a game with FPS above 240hz.
regarding the 27" 1080p problem.
I studied this extensively on the physiology book i have. Based off those directions from the book and me cross referencing the size of the monitors. To match the optimal focal point, u would need to sit at least 38"-40" away from the monitor to have the same focal point as someone with a 24.5" monitor sitting at 24-26" away. But the advantage of 27" 1080p is that it's easier for precision purposes because everything is bigger. Which means easier head shots, easier shot on goal, larger targets, etc(even IF you sat further away).
I knew this when i started losing every single match i played. The response etimtes were good but i'm not reacting fast enough since my retina has to move a longer distanace. So i adjusted the distance, and i managed to pretty much win every match after that.
Siye
Post by Siye » 03 Jul 2020, 12:58
RLCScontender wrote:
02 Jul 2020, 22:25
kofman13 wrote:
02 Jul 2020, 08:18
when you say the VG259QM is excellent but only over 240hertz, is this without ELMB? Is the VG259QM still a decent monitor if you set it to 240@80 on games you dont get over 240fps on? Some games i do get 280 fps easy and some like warzone, i dont. Thanks
axaro1
Post by axaro1 » 03 Jul 2020, 14:50
Siye wrote:
03 Jul 2020, 12:58
If you use Gsync/Freesync and your fps fluctuates sub 240hz you should stick to OD60 because OD80 becomes borderline usable sub 220hz due to overshoot.
If you play with a fixed refresh rate of 240hz with no Adaptive Sync, OD80 is usable with some minor overshoot (more than on the MAG251R), if you use ELMB-Sync at this refresh rate you eliminate a good % of corona artifact and you noticeably improve motion clarity.
OD80 is more suited for 280hz.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
Siye
Post by Siye » 03 Jul 2020, 17:57
axaro1 wrote:
03 Jul 2020, 14:50
Siye wrote:
03 Jul 2020, 12:58
If you play without a fixed refresh rate of 240hz with no Adaptive Sync, OD80 is usable with some minor overshoot (more than on the MAG251R), if you use ELMB-Sync at this refresh rate you eliminate a good % of corona artifact and you noticeably improve motion clarity.
Thanks, one more question have you tried the VG259QM with just ELMB with no adaptive sync? people have mentioned that its better than ELMB-SYNC for certain situations. Will you be posting the g2g numbers in your part 3 review for the VG259QM?
Just so im understanding you correctly on a fixed refresh rate 240@80 is ok, with minor overshoot? and elmb can be enabled for better motion clarity? How much does respone time suffer on 60 OD in oppose to 80? Is the minor overshoot worth it for a better responce time? Sorry im not expert but id like to know as i play games competively.
On tftcentral there is a review on the VG279QM and the best g2g average and suggested setting to use is 240@80 which gives a responce time of 4.2 (best mode to use "hardware unboxed" claims). I understand the VG279QM & VG259QM use different panels? So i guess my question is do you have the numbers? how different is the 27 inch version from the VG259QM? I dont know the numbers etc for the VG259QM but im assuming at 240@60 response times dont suffer enough to not use it over 240@80? Thanks
Locked
