Other than the xl2546s cos thats always sold out.
idc about colors just motion clairity and low input lag, i tried the xf242q twice and the motion clairty was just bad. Are there any other 25 inch 240hz/144hz monitors i should look out for?
the omen x 25f is £350 here but i saw it at £320 around march
Is the hp omen 25f best monitor for response time?
PixelDuck87
Re: Is the hp omen 25f best monitor for response time?
Judging by what people say around here ASUS VG259QM is very good.
EastEndBear
Rtings has input lag at the variable refresh rate for the ASUS VG279QM at 1.7ms and the Omen 25f at 2.6ms.
I assume you mean "XF252Q" if not I never seen a "XF242Q".
The Acer XF252Q and the HP Omen X 25f uses both the same (released in 2019 "AUO M250HTN01.9") panel so if the motion clarity was not satisfying you I think it will be the same for you with the HP Omen X 25f.
A bit late, but I recently bought the omen and until now it's the fastest monitor (input lag) I've experienced and the motion clarity is outstanding.
It even feels faster on the fastest response time mode 4 instead of the recommended 3 by rtings.
Thanks for this message,
Looks like im going to be buying this monitor the g-sync version as i can get for the same price as the 25f
I was debating between this, the kd25f and the VG262QX but ive seen soo many good things about the motion clarity of this.
Do you see alot of overshoot on mode 4?
