Thank you for taking the time to take picture of OD 60 vs OD 80, i really appreciate it @axaro1axaro1 wrote: ↑10 Jul 2020, 07:49Blehhh wrote: ↑08 Jul 2020, 00:58
Great summary on everything collected so far.
How is the VG 259QM in comparison to the rest? do you mind sharing the response time and input lag of the VG 259QM @280hz also @240hz? is the input lag better than asus VG 279QM at 280hz? curious to know if the input lag is better on the VG 259QM than VG 279QM @ 280hz and 240hz?
still waiting for the quintuple review finale![]()
which do you personally prefer OD 60 or OD 80?
btw may i ask what gpu you are currently using?
