Reducing Input Delay with Nvidia Inspector
BTRY B 529th FA BN
Re: Reducing Input Delay with Nvidia Inspector
Post by BTRY B 529th FA BN » 05 Aug 2020, 11:33
MaxTendency
Post by MaxTendency » 05 Aug 2020, 11:42
BTRY B 529th FA BN wrote: ↑
05 Aug 2020, 11:33
Is Cool N Quiet and C-States enabled in your bios?
Also what is your windows power plan processor power management settings?
Every single power saving I could find in bios are disabled. Power plan is a custom one with everything set to high performance and disabled power saving. The tests were done while having nothing else running in the background to reduce variables.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 05 Aug 2020, 12:23
MaxTendency
Post by MaxTendency » 05 Aug 2020, 14:30
05 Aug 2020, 12:23
Mine varies between 1.96 to 2.20 on average maybe more maybe less. Your dpc latency is pretty good. I've noticed Heterogeneous thread scheduling & Heterogeneous short running, scheduling policy can have an impact on dpc latency. H thread scheduling at Performant Processor + H short running thread scheduling at Efficient Processor with Cool N Quiet & C States enabled will lower the dpc latency to the numbers your showing (mid .70us) but Cool N Quiet & C states are terrible for gaming. How did you get it that low? Via power plan tweaking?
What is this 'nvlddmkm.sys - patched' driver?
On w10 my avg interrupt to process is very stable at 2.1-2.2. However on w7 it jumps around from 1.5-2.7 (most of the time its 2.5ish) , despite that mouse input on a fresh installed w7 is league apart from a fully tweaked w10. I believe the lower interrupt to process latency on w10 comes from its updated scheduler that is more optimized for ryzens.
05 Aug 2020, 12:23
Mostly from this guide. This is my w10 latencymon results from 4-6 months ago (without any inspector profiles.) Only thing I did different from the guide is I used "iobit unlocker" to manually debloat windows rather than using script.
05 Aug 2020, 12:23
Its just the nvidia driver patched with Pixle Patcher
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 05 Aug 2020, 16:19
chenifa
Post by chenifa » 05 Aug 2020, 17:07
Posted my results but since my posts need to be approved first it ended going back in time to page 2
ffs_
Post by ffs_ » 06 Aug 2020, 01:14
MaxTendency wrote: ↑
04 Aug 2020, 10:04
I would suggest trying out, "Moderate" memory allocation policy and see how that goes.
Yep, I have been using it already.
04 Aug 2020, 10:04
There are also some settings in "Extra" that you might wanna fiddle around with. Try
ColorCompressionEnabled - on
D3D9_Control_Bits - Force 1bit compression
MCForceHostStagingBufferSize - 0x00000080 (if you wanna try lower than 80 some games *might* stutter)
Tried these options + registry tweak, played for 2 days and haven't noticed any improvements in input-lag/mouse movement/hitreg.
IMHO the main improvement comes from picking certain driver version. I used to use 347.25 (Win 8.1) and it was the best for me, now I use 451.67 (Win 10 v2004), and I think it gives me the best results in terms of input-lag/mouse movement/smoothness.
04 Aug 2020, 20:22
are these reduce latencies measurable with LatencyMon?
I don't think there is direct correlation between input-lag and DPC latency.
Fixing DPC latency might help if you get lags/stutters/freezes, but if your DPC latency is more or less fine alrdady, I doubt you will gain anything from lowering these values. For example, I have had max 200 us during the game on Windows 8.1, and now on Windows 10 I have max 380-400. But guess what? The game feels significantly smoother on Windows 10.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 06 Aug 2020, 06:56
ffs_
Post by ffs_ » 06 Aug 2020, 13:22
Sure.
mckayvz
Post by mckayvz » 09 Aug 2020, 10:02
Hey I followed op instructions and I got this error popping up every time I try to import a profile. I'm using a laptop (Dell ins 7567). May I have your screenshots of NI for the Riot LLHP profile so I can try to do it manually?
Some profile(s) could not imported error: https://imgur.com/TJTFCsh
