Reducing Input Delay with Nvidia Inspector
MaxTendency
Re: Reducing Input Delay with Nvidia Inspector
Post by MaxTendency » 09 Aug 2020, 13:48
mckayvz wrote: ↑
09 Aug 2020, 10:02
Hey I followed op instructions and I got this error popping up every time I try to import a profile. I'm using a laptop (Dell ins 7567). May I have your screenshots of NI for the Riot LLHP profile so I can try to do it manually?
Some profile(s) could not imported error: https://imgur.com/TJTFCsh
Your Inspector version seems to be outdated. Try getting the latest one from here : https://github.com/Orbmu2k/nvidiaProfil ... r/releases
mckayvz
Post by mckayvz » 09 Aug 2020, 14:31
MaxTendency wrote: ↑
09 Aug 2020, 13:48
mckayvz wrote: ↑
09 Aug 2020, 10:02
Oh it worked, tkx. I saw it said pre-release so I thought it was BETA build haha
tosh
Post by tosh » 15 Aug 2020, 08:31
i used the Riot Low_Latency_High_Performance v2 config , is it normal that it changed my settings in nvidia manage 3d settings. it turned off low latency mode for example surely thats bad
MaxTendency
Post by MaxTendency » 16 Aug 2020, 05:24
tosh wrote: ↑
15 Aug 2020, 08:31
Yes thats normal, inspector and nvidia control panel are just GUI , they simple make changes to the driver settings.
tosh wrote: ↑
15 Aug 2020, 08:31
That however is not normal. Probably some bug/import error. Set it to Ultra manually, you can also try On.
Conan wrote: ↑
30 Jul 2020, 03:59
I'd do that but I wish to know more in depth what I'm doing and what does that specific command do :D
I have updated OP with some more information about some specific settings from Melody's site. viewtopic.php?f=10&t=7323#p55433
TN_fun
Post by TN_fun » 16 Aug 2020, 06:17
I used Low_Latency_High_Performance v2 config and it made my GPU clock to max after reboot. Does not reset at idle. It is not normal. I returned the default settings.
Conan
Post by Conan » 16 Aug 2020, 14:23
16 Aug 2020, 05:24
Conan wrote: ↑
30 Jul 2020, 03:59
Ty man. Ill check it out!
csplayer
Post by csplayer » 26 Aug 2020, 12:16
03 Aug 2020, 13:15
Simon95 wrote: ↑
03 Aug 2020, 10:30
I dont have "DisableWriteCombining". Should i create a new registry key?
Yes create a DWORD, and then restart pc. You should lose a mesureable amount of fps (4-5% for me) but input should feel snappier. You can then delete the key if you want to revert back.
It has seemingly increased my FPS a lot.
I notice this mostly in busy deathmatch servers my lowest fps has improved with about 50 frames.
Also i made a fps benchmark using the fps benchmark map in CS:GO.
Before ( No registry key for DisableWriteCombining ): https://imgur.com/3kavZsA
After DDS on 1: https://imgur.com/jJQgB7j
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 24 Nov 2020, 17:40
Simon95
Post by Simon95 » 26 Nov 2020, 04:02
Buffers
What to expect when changing all these values: The lower, the better input and the worse fps. The higher, the better fps and the worse input.
OGL_PULL_MEM_BUFFER_SHARED_THRESHOLD - This controls a dynamic threshold by setting a value to which the memory pull buffer "moves". Not adviced to set this below 0x00000080.
OGL_PULL_MEM_DEFAULT_BUFFER_SIZE - Default memory pull buffer size (starting value). Not adviced to set this below 0x00000080.
MCFORCEHOSTSTAGINGBUFFERSIZE - Sets the Host Staging Buffer Size. This is a global buffer that changes pretty much everything in the GPU queue. Not adviced to set this below 0x00000020.
MAX_PENDING_CMD_BUFFERS - Sets the max pending command buffers that are allowed at the same time. Not adviced to set this below 0x00000001.
I cant find these settings in my profilenvidiainspector. How can i unlock this settings?
ffs_
Post by ffs_ » 26 Nov 2020, 08:54
Simon95 wrote: ↑
26 Nov 2020, 04:02
Make sure you're using proper Nvidia Profile Inspector: https://github.com/Orbmu2k/nvidiaProfil ... g/2.3.0.12
