How do you compare it against your XL2546 ?speancer wrote: ↑16 Aug 2020, 05:28It's perfectly fine on "Fastest" overdrive on 240 Hz. I have MSI Optix MAG251RX on my desk right now. I mostly use this monitor with fixed 240 Hz for competitive gaming with overdrive "Fastest", Adaptive-Sync disabled. I'm pretty sure @purplew is describing VRR performance, then yeah, for lower frame rates in Adaptive-Sync mode you need to switch overdrive setting to "Fast", but that's normal behaviour for many monitors (lack of variable overdrive). Hardware Unboxed also mentions this and recommends "Fast" overdrive for Adaptive-Sync, as it delivers the best performance across the refresh rate range on the lower side (144 Hz and less), but "Fastest" overdrive is also the best with Adaptive-Sync for refresh rates closer to 240 Hz.PixelDuck87 wrote: ↑15 Aug 2020, 16:59Based on hardwareUnboxed review only 49.1% of transitions are within refresh window at 240hz on 'fast' setting. If 'faster' as you say is unusable then MAG251RX should not be considered at all for 240hz competitive gaming?purplew wrote: ↑15 Aug 2020, 14:23Yeah, honestly I've got to say - the MAG251RX's fastest setting (there's normal, fast, fastest) is completely unusable. I know that RLCSContender said it's the best but just no. Especially in web browsing it's hurting my eyes a lot. Fast is completely fine though.
Also it's even noticeable in games in fast motion scenarios, it just messes up everything
If I had to pick a monitor again I'd either go the XB253Q GX or the AW2521HF that's like $200 cheaper or a good TN, strobing is not too useful on the mag unless you have 200+ fps, but then it's a bit dim, and fastest overdrive is not really usable. Fast overdrive combined input lag + response time is not quite on par with the XB253Q GX from the reviews ive seen.
(And to the XB273 X?)
I've played shooters all morning today. I think you're right, "Fastest" is usable for me, as long as brightness and contrast are kept near 50. The increased contrast-effect from the overshoot you get on "Fastest" can be slightly disorienting and overwhelm me in tense situations, but decreasing the brightness/contrast works fine actually.
When not playing games, "Fastest" makes the text unreadable (you get corona and blue trails when scrolling in browser), therefore "Fast" is great for a casual browsing experience, "Fastest" is only good for games.
However, I'm finding even better results with simply enabling Anti Motion Blur, and keeping the contrast at 50. Yes, the screen is dim, but once you get used to the dim-ness it's actually FAR superior to either "Fastest"/"Fast" no matter what. The motion clarity is actually really impressive, if it wasn't for the motion blur reduction I think I wouldn't keep this monitor.
Like, I've played with "Fastest" for about 3 hours non-stop, then decided to enable Anti Motion Blur. The difference in motion clarity is gigantic. If it wasn't for me playing 3 hours nonstop I wouldn't have noticed it as much, but it's such a huge difference. It sucks that there's a tiny bit of crosstalk - if anyone knows how to reduce it please let me know. But yeah it's a huge, huge difference.
Also keep the contrast at 50, not any higher than that. The default value of 70 when enabling AMB is bad, it clips a lot of bright objects. 50 makes it even dimmer but honestly if you can get used to it - and I did - it's a gamechanger
