Hello guys.
I can see in the OSD menu that Freesync is somehow enabled whenever I activate G-sync. When I disable G-sync OSD menu will show 1920*1080p@240hz
I found viewtopic.php?f=13&t=6118&p=45991&hilit=xl2740#p45991 on this forum, he got the same problem. I tried to use CRU to make the monitor FreeSync incompatible i had no luck, I cant edit the monitor range limit.
When I enter games I dont get the G-sync logo.
I uploaded 4 pictures https://imgur.com/a/FvGPnD9
Can someone help me?
BenQ zowie XL2740 Freesync
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — BFI / ULMB / ELMB / DyAc / framegen / LSS / etc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory: Display Science Section
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
