Alpha
I believe sharing FW and experience is important here. I was pretty surprised after reading Rtings re-evaluate based on the OD120 because it’s clearly not the case with what I am seeing with my display on FW 105. Did they ever mention what firmware they had? They mentioned checking again if there’s a FW update. Maybe I missed it?
I haven’t tested any blur methods but I seem to lean more towards 280hz, OD120, VRR off, DCDI (or whatever it’s called Dcci or whatever in display settings, Off. just reporting what mine is at not real reason why) Gsync, Vsync of course off. With the titles I have experimented with, Siege, Warzone, BFV, and nothing has stood out in terms of blurring, ghosting, or tearing. Meaning I have not noticed anything that I’m like wooo back back back. Just curious if anyone has tried these? I haven’t taken a closer look but to be 100% clear I have not had the freshest eyes during gaming sessions. What I believe is the difference and please understand this should be taken with a massive amount of not enough sample time, not looking super closely or literally just plain missing the obvious, is the response time. It’s seems faster enough I haven’t changed it back since experimenting. I made the rtings suggested change and did a close look at the UFO test and that was a huge no back to OD120.
After stumbling back in here (thank you too all!) and seeing the suggested shadow boost change, I believe mine is set to dynamic/auto or whatever mode it’s called that isn’t 1/2/3 I’d have to look I just know it’s there. I’m looking forward to looking at this today when I haves moment.
I don’t think PC specs matter here but my FPS is around 400 in Siege most of the time and Warzone mostly around 180ish with rare dips to 155 and highs around 205/210 during gameplay.
I have Windows GPU advanced settings enabled and respective games .exe added to Windows apps. This is in 2004.
singleDADAN
OMG so fast monitor and response and no input lag, no trails or ghosting around mouse point or in game i have had before xg258q so much ghosting and higher input lag, this monitor rocks, im i competitive player and im impressed. sorry for my english the monitor is 27inch version with 280hz no elmb no gsync and od 80- Attachments
- Screenshot_18.png (20.25 KiB) Viewed 17326 times
singleDADAN
guys i still cant believe how fast and responsive is this monitor i just cant, like im using my old trusty crt oced to 153hz, if u want best of the best for competitive playing this is it...
TN_fun
cool screenshot dude
Stevie66
You took a Windows screen shot of the ufo. You need to actually take a picture of your monitor with a camera...singleDADAN wrote: ↑04 Sep 2020, 07:16OMG so fast monitor and response and no input lag, no trails or ghosting around mouse point or in game i have had before xg258q so much ghosting and higher input lag, this monitor rocks, im i competitive player and im impressed. sorry for my english the monitor is 27inch version with 280hz no elmb no gsync and od 80
- ko4
Quarksie
hello does someone has a good tutorial to overclock the VG259QM with CR? I've seen someone on this forum overclock it to ~300hz
Quarksie
Quarksie
Stevie66
I see some people on different FW, does this monitor allow you to update FW? I don't see anything on the Asus site.
Andrikuh
Hello, I would like to know the best configuration to play competitive VALORANT. My performance is + 280fps. I hope you can help me, thanks!
- axaro1
280hz
OD120
Adaptive Sync OFF
Shadow Boost lvl1
Fps Mode/Racing mode (I prefer the colors of FPS mode but racing mode is less saturated and more accurate)
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
