howiec
Post
by howiec » 25 Oct 2020, 21:14
So uh, figured I'd share this with you guys but I think I'm actually getting 433Hz checked using none other than
https://www.testufo.com/frameskipping of course. Been running this since I got the monitor with no issues thus far.
Chief or others - Can you confirm this is really producing 433Hz "physical" refresh?
Post
by jorimt » 25 Oct 2020, 21:19
howiec wrote: ↑25 Oct 2020, 06:54
Now I just need an RTX 3090 to keep those minimum frame times as high as possible.
CPU/RAM are primarily responsible for minimum framerates (e.g. 0.1% frametimes), not the GPU, FYI. But if by "minimum frame times as high as possible" you mean you want slightly higher average/maximum FPS, go for it.
howiec
Post
by howiec » 25 Oct 2020, 21:28
jorimt wrote: ↑25 Oct 2020, 21:19
I want both for sure.
I agree that CPU/RAM bottleneck will be the main factor in the majority of the drops but at the same time in Apex Legends at least, I've noticed that certain areas/environments are clearly GPU bottlenecked (CPU usage remains relatively constant and "low / moderate" vs GPU usage spikes 90%+ even at low FPS cap).
Currently running 24/7:
8700k @ 5.03 GHz, 0 AVX offset
DDR4 @ 3216 MHz, 13-14-14-28-350 + other optimizations
Plan to upgrade rest of system as soon as something worthy is out after I get my RTX 3090.
Post
by Chief Blur Buster » 25 Oct 2020, 21:29
howiec wrote: ↑25 Oct 2020, 21:14
Testing now. Standby.
Post
by Chief Blur Buster » 25 Oct 2020, 21:34
I got 433Hz to display, but it's frameskipping. Can you post a photo if it's zero frameskipping?
Testing other undocumented refresh rates now using my usual overclocking tricks, standby.
howiec
Post
by howiec » 25 Oct 2020, 22:19
Yeah, to clarify, I'm getting frameskipping at anything above 366Hz but just wanted clarification that displaying at 433Hz with frameskipping = ~360Hz in reality. Is that true?
Also, here's what I get at 366Hz:
howiec
Post
by howiec » 25 Oct 2020, 22:55
Warning: Could be placebo without further testing
On a side note, with some quick "unscientific" tests by playing some games and dragging windows vertically up and down at various speeds, I perceive less motion blur even with the frameskipping at 433Hz vs default 360Hz.
Hence why I was asking if we're truly seeing a "physical" somewhat 433Hz (or at least significantly higher than 360Hz) refresh and not just a 433Hz setting with only ~360 or say ~370 Hz in reality.
In competitive games I'm willing to tolerate some frameskipping (minor stutter?) for decreased motion blur and faster scanout overall.
...or maybe the frameskipping has some sort of strobe-like effect improving motion clarity.
howiec on 26 Oct 2020, 00:04, edited 1 time in total.
Post
by Chief Blur Buster » 26 Oct 2020, 00:04
howiec wrote: ↑25 Oct 2020, 22:19
Correct. 366Hz is what I am able to get without frameskipping. Anything above just simply frameskips.
For improved clarity above 360Hz, there are possible causes. For example, GtG pixel response may be affected, or that the non-frameskipped frames are actually refreshing in 1/433sec. I will need to use a 960fps high speed camera to determine the cause. But, rarely, it is sometimes possible for clarity to improve somewhat even with frameskipping, because of other changes that occur (like GtG times or scanout times). If so, latency could be slightly lower but much more jittery (due to frameskipping creating latency randomizations).
howiec
Post
by howiec » 26 Oct 2020, 00:17
Chief Blur Buster wrote: ↑26 Oct 2020, 00:04
Yeah, seems it could be more complex.
When I run my PG258Q at 258Hz, the mouse cursor noticeably stutters but I perceive slightly improved motion clarity during gaming.
Whereas I don't notice any mouse cursor stutter on my PG259QN at 433Hz but I haven't really examined that in detail. Clearly, it's likely stuttering, just it's harder to notice at these higher frequencies.
