Gotcha, I'll keep mine then.jorimt wrote: ↑26 Oct 2020, 22:10The difference between 0.5-0.7 and 1.03 dE is virtually imperceptible to the eye, and TFT Central called their OOTB calibration "excellent," with them only needing to bring the brightness down, so If you keep it in "Racing Mode" and only adjust the brightness, I think you have your answer, as your report is very close to theirs (yours appears to have even lower dE in the grayscale, as well as in some colors).spankjam wrote: ↑26 Oct 2020, 19:35Gotcha, I have the i1Display but I was wondering whether the Asus calibration report is indicative of the panel having a better overall color accuracy with 0.5 or 0.7 than the mine that came with 1.03 or will I end up having nearly the same result when calibrated at home?
I mean 700 bucks isn't a lighthearted purchase when it comes even to gaming monitors so I'd like to make sure I'd get at least a good batch?
I just found tftcentral's report:
And that's mine:
As for whether you'd have "nearly the same result when calibrated at home," since it's already factory calibrated, and said calibration is already so close to target, the only thing a DisplayCAL ICC profile would do, for instance, is try to correct further on top of the existing factory pre-cal (it wouldn't overwrite it).
The pre-cal is close enough that if you target 2.2 gamma with a D65 whitepoint with DisplayCAL, you probably won't be able to tell much if any differences vs. out-of-box, but you could always try; should only take about ~20 minutes.
That said, I'd honestly recommend against an ICC profile if the factory cal is accurate enough, as you avoid further processing and any potential ICC artifacts (introduction of minor gradient banding, slight reduction of contrast ratio due to software manipulation of RGB levels, etc). That, and ICC profile app support is spotty, so it may not even apply in every game.
Although I noticed tiny scratches at the bottom of the screen? Near the bezel where the evil eye is, do you think this comes from installing the panel? They aren't big, look like this
