Official Asus ROG Swift 360Hz PG259QN Owners Thread
Chillen
Yes 1660 Super. I tried all display ports at different refresh rates. I tried included hdmi cable and my own hdmi cable. Switched to the old 970 and tried all cables and ports as well.
I unplugged the rog swift and plugged it back in. The problem went away and monitor is working flawlessly. I don't know what to do at this point.
Chillen
Here is a picture of what the screen looked like. I also replied to your questions in a separate post. Thanks for the help.
- Rog Swift Pink Screen.jpg (1008.81 KiB) Viewed 8004 times
Stevie66
Strange how the OSD isn't messed up like the rest of the screen
howiec
So I had a very strange issue on mine recently but I've also been messing with other stuff. I saw vertical bar artifacts all over my screen but the OSD was rendered correctly so I knew it was likely a signal issue vs a panel issue.Chillen wrote: ↑15 Nov 2020, 11:17Yes 1660 Super. I tried all display ports at different refresh rates. I tried included hdmi cable and my own hdmi cable. Switched to the old 970 and tried all cables and ports as well.
I also tried different cables, ports, resolutions, refresh rates, timings, etc. to no avail.
Then I DDU uninstalled my Nvidia driver (safe mode, no internet), reinstalled it, and everything was back to normal.
Seems like something related to the driver somehow got corrupted.
Chillen
So I had the vertical bars going across the screen as well. It's just hard to see in the picture. So, it must be a driver issue because it sounds like we had the same problem. Weird thing is that I did try another monitor and it worked fine. I don't know why a driver issue would only effect this monitor.howiec wrote: ↑15 Nov 2020, 19:12So I had a very strange issue on mine recently but I've also been messing with other stuff. I saw vertical bar artifacts all over my screen but the OSD was rendered correctly so I knew it was likely a signal issue vs a panel issue.Chillen wrote: ↑15 Nov 2020, 11:17Yes 1660 Super. I tried all display ports at different refresh rates. I tried included hdmi cable and my own hdmi cable. Switched to the old 970 and tried all cables and ports as well.
Stevie66
If it's vertical bars then it's the issue that 240hz 24" AU Optronics panels had, shame they have it again for the 360hz versions. My Alienware 240hz had it think it's called pixel inversion artifacts and looks like a lot of vertical lines down the screen almost like a CRT
howiec
I just looked up pixel inversion artifacts and what I had was totally different than what I see in example pics from the Google search, unless it was a super extreme version or something.Stevie66 wrote: ↑15 Nov 2020, 23:47If it's vertical bars then it's the issue that 240hz 24" AU Optronics panels had, shame they have it again for the 360hz versions. My Alienware 240hz had it think it's called pixel inversion artifacts and looks like a lot of vertical lines down the screen almost like a CRT
I should've taken some pics but basically imagine alternating vertical bars roughly 5 or so pixels wide were solid and static in position. The other bars were somewhat correct but I believe still had some other types of artifacts.
Also, the weird thing is that mine was resolved after a driver uninstall/reinstall... Perhaps it was somehow related to the additional custom resolutions and refresh rates I had although the single one I'm using now is exactly the same as the one I had prior to the driver reinstall (prior I also had other custom resolutions, just not in use).
Stevie66
From some other users here, mine and others were like this that randomly showed up and went away, hopefully the 360hz monitors don't get this problem anymorehowiec wrote: ↑16 Nov 2020, 06:37I just looked up pixel inversion artifacts and what I had was totally different than what I see in example pics from the Google search, unless it was a super extreme version or something.Stevie66 wrote: ↑15 Nov 2020, 23:47If it's vertical bars then it's the issue that 240hz 24" AU Optronics panels had, shame they have it again for the 360hz versions. My Alienware 240hz had it think it's called pixel inversion artifacts and looks like a lot of vertical lines down the screen almost like a CRT
howiec
Yeah, that's different than what I had.
Another strange thing is that I only had the problem on my PG259QN while my PG258Q was running fine in tandem.
Oh well. Hopefully it doesn't recur.
andrelip
I had that. Tried to reboot the computer, unplug the cables, etc. What solved for me was disconnecting the monitor from the power.Chillen wrote: ↑15 Nov 2020, 23:24So I had the vertical bars going across the screen as well. It's just hard to see in the picture. So, it must be a driver issue because it sounds like we had the same problem. Weird thing is that I did try another monitor and it worked fine. I don't know why a driver issue would only effect this monitor.howiec wrote: ↑15 Nov 2020, 19:12So I had a very strange issue on mine recently but I've also been messing with other stuff. I saw vertical bar artifacts all over my screen but the OSD was rendered correctly so I knew it was likely a signal issue vs a panel issue.Chillen wrote: ↑15 Nov 2020, 11:17Yes 1660 Super. I tried all display ports at different refresh rates. I tried included hdmi cable and my own hdmi cable. Switched to the old 970 and tried all cables and ports as well.
I have an Asus Strix 3080
