desync is everywhere in windows in bios everywhere wtf you talking aboutvictor910 wrote: ↑04 Jan 2021, 04:08ok then, do you know how many different threads on cheats developers forums something like this:
desync chams flicking when having over 150 fps
Efficiently resolving desync side
Why are people using layer 6 playback rate?
How to apply resolver angle?
Legit AA problems
Setting up layers for different feet yaws
All these threads result in founds with the word "desync"
this results just from the first list only.
I believe I provide a clear answer to why you have this "input lag" problem.
You guys are my last hope for fixing my problem
Unixko
Re: You guys are my last hope for fixing my problem
victor910
ok, I'm trying in a more simple form.
I just try to say, if someone uses wallhack, you do not disable he's wallhack if you grounded power at your house.
akylen
Thats the point , with what we have , you can think everyone use a wallhack even if they dont , they're bad, but with the problem we got , we can't be better
but if you think like that , then everyone is wallhacking , which is not true
- dervu
Dude, how can someone's wallhack alter your mouse behavior? It is not only about desync but also mouse movement and having off spray even while not seeing enemies.
victor910
Of course wh do not change mouse behavior.
I just provide a more basic example.
akylen
Little question , does that look normal for you guys
https://www.youtube.com/watch?v=OV9VEPT2LM8
Idk why but i die like that even on warzone , without jitter/packet loss or anything
i know its mm but still , is it normal ?
readtext
had the same problem with a zyxel modem(vdsl), somehow ppl got insanly fast peeking me. could fix it with a draytek modemakylen wrote: ↑06 Jan 2021, 21:13Little question , does that look normal for you guys
akylen
I tried with a Linksys e900 router , but didnt changed anything , also what i got is a fiber 1GB down , 400 Mbps up.
Also when i play the game isn't smooth even with high fps , like in warzone +100 fps doesn't feel like it
victor910
ok, I will try one time.
final decision WHEN your shot will be registered make it by SERVER.
Server operated base on pings and fps on EVERY player who connected to him right now, as well server use another condition but we will be talking about this later.
In short story,
if someone have high ping this YOURS problem.
if someone has fps drop this YOURS problem.
I know this stupid, but question why? please direct to games developers.
Cheaters know about this stupid algorithm and easy to use, generate a FAKE problem with FPS and PING for affected to on opponent input lag.
In short story,
- nuggify
Please for the love of god comment with something on topic to the thread. The OP said all his issues are present while on desktop, and even in BIOS. It has zero to do with anything you are talking about, we are here trying to fix a real problem and you are just rambling about cheaters. This is not related to any specific game. Its not software.victor910 wrote: ↑08 Jan 2021, 03:10ok, I will try one time.
In short story,
