DukeDice929
Post
by DukeDice929 » 30 Jan 2021, 13:14
16nguyent wrote: ↑29 Jan 2021, 22:39
Can someone give me a good setting for this monitor, specific warzone. I want to see clear while having good frame. There are so many different settings on here. I'm not sure what to set up on my nvidia control panel setting either. I have a 2080 Ti
Look up this post:
viewtopic.php?p=63100#p63100
lostyBLUR wrote: ↑29 Jan 2021, 23:37
Does shadow boost increase input lag?
Personally, I've never heard of "shadow boost" affecting input lag on any monitor. Try it and post here your observations.
My bad English :0
Discorz
- VIP Member
Post
by Discorz » 02 Feb 2021, 05:49
There is this firmware that has been uploaded for quite some time: 2020/03/06
direct download:
https://dlcdnets.asus.com/pub/ASUS/LCD% ... Driver.zip
What's confusing is, on their website the version is 2020/03/06 and everybody on this forums have their firmware called MCM103/104/105. And then when you download the asus provided firmware and open some files to check wich one it really is it's version 11/13/2019,1.0.0.0. Whats up with that?
So did you update it and how? Which MCM10x version would be the last one asus provided?
I don't own this monitor yet, but plan to get one despite all it's flaws
axaro1
Post
by axaro1 » 02 Feb 2021, 05:54
Discorz wrote: ↑02 Feb 2021, 05:49
direct download:
It is not a firmware, it's a driver that forces the icm profile.
You cannot update your firmware on the VG259QM.
StareX
Post
by StareX » 02 Feb 2021, 17:02
BTRY B 529th FA BN wrote: ↑02 Feb 2021, 06:16
direct download:
Thanks for the reply, yes it's only an icm profile.
I ended up returning the monitor. It's a very nice monitor however for some reason while running 280Hz (VG279QM btw) it would boot up in 144hz mode. Couldn't figure it out so I returned it.
It's a small bug that can be fixed with CRU tho... :/
Discorz
- VIP Member
Post
by Discorz » 03 Feb 2021, 02:46
Well, I'll be damned! Just realized that it could be a profile before seeing your answers, cause it doesn't make sense.
I ordered it today and am excited to play with it just like a kid little haha
. The monitor is not perfect but tweeking those setting gets my blood flowing. Is that weird?
Discorz
- VIP Member
Post
by Discorz » 03 Feb 2021, 04:06
Btw, is that 60Hz input lag present on every firmware version (MCM103/104/105)?
PixelDuck87
Post
by PixelDuck87 » 03 Feb 2021, 13:18
Anyone know why freesync can randomly stop working in Apex also it never works in csgo at all. To make freesync work in Apex I need to restart PC then after few hours it will become solid 280hz again...
Discorz
- VIP Member
Post
by Discorz » 03 Feb 2021, 16:27
PixelDuck87 wrote: ↑03 Feb 2021, 13:18
Check its enabled in OSD, also in nvidia cp or amd software, for global or specific game. If you're unsure if its working or not you can use "FPS counter" provided within monitor OSD to show you if refrash rate is fluctuating/synced with frame rate.
Also for adaptive sync to work ingame frame rate value has to be below the set ingame refresh rate value. For exmaple if your pc hits 241fps (with ingame resolution and refresh rate set to 1920x1080@240Hz) the adaptive-sync is disabled. So make sure you're resfresh rate setting is set to highest.
Sometimes turning monitor on/off can help.
