Stevie66
Post by Stevie66 » 08 Feb 2021, 18:08
Discorz wrote: ↑
08 Feb 2021, 17:54
Stevie66 wrote: ↑
08 Feb 2021, 17:30
What device did you use to test your input lag?
I did not use any device. It's very noticeable in this video, based on that I concluded its not that high.
https://youtu.be/xGluvAAE5RU?t=541
Well they are all the same, firmware makes no difference, that video doesn't show much except his experience with his mouse movements and windows moving that he can notice but us the viewer can't.
Discorz
VIP Member
Post by Discorz » 08 Feb 2021, 18:14
Stevie66 wrote: ↑
08 Feb 2021, 18:08
Well if I recorded my self doing the same thing it wouldn't look as bad and laggy.
Discorz
VIP Member
Post by Discorz » 08 Feb 2021, 18:26
If anyone wants to see some more detailed VG279QM ufos check it out
viewtopic.php?f=2&t=8235
VIEW IN FULL RESOLUTION FOR BETTER QUALITY!
Strobed and sample-and-hold ufos (5844x3660)
Stevie66
Post by Stevie66 » 08 Feb 2021, 18:59
Discorz wrote: ↑
08 Feb 2021, 18:14
Stevie66 wrote: ↑
08 Feb 2021, 18:08
Lag is his delay moving the mouse and the window moving, something we can't see in that video because it's down to the ms, has nothing to do how crappy the window moving looks
Discorz
VIP Member
Post by Discorz » 09 Feb 2021, 02:39
Stevie66 wrote: ↑
08 Feb 2021, 18:59
Noo, I know what input lag is.
The only thing you can see in the video is that the delay is more pronounced/noticeable/higher than usual, from the time he moves the mouse and the window starts moving. At least I can see it. An he even said he measured more than 34ms @60Hz (34.73ms, RTINGS 35.1ms). So if that delay in video was 35ms, mine was not as high is what I meant to say. Don't get me wrong, it was still noticeably higher than other 60Hz monitors I've tried.
Maybe the choice of my words confused you since English is not my strongest side. :)
Numbers are here:
https://www.aperturegrille.com/reviews/ ... /#InputLag
https://www.rtings.com/monitor/reviews/asus/vg279qm
il3c
Post by il3c » 16 Feb 2021, 09:24
Hello,
I wanted to know if some of the users of the vg259qm have the same trouble like me : in specific games like CSGO and LoL sometimes my monitor downclock to 144hz when I'm on "fullscreen" and "disable Fullscreen optimization" on the ".exe". Is it because this games are awful to deal with new stuff or I miss something ?
I did use CRU monitor with only 280hz in the configuration.
i7 8700k 5GHz,GTX 1080, Asus ROG PG278Q 144hz, Asus ROG swift VG259QM 280hz
davidoo
Post by davidoo » 17 Feb 2021, 10:00
il3c wrote: ↑
16 Feb 2021, 09:24
Hello,
Mine does the same thing. i have the 27 version. I have seen a lot of people on reddit with the same issue :(
Stevie66
Post by Stevie66 » 17 Feb 2021, 19:35
il3c wrote: ↑
16 Feb 2021, 09:24
Hello,
Mine used to do that but hasn't since I followed this guys CRU guide in the first post
viewtopic.php?f=2&t=7964
il3c
Post by il3c » 18 Feb 2021, 11:45
Stevie66 wrote: ↑
17 Feb 2021, 19:35
il3c wrote: ↑
16 Feb 2021, 09:24
Hello,
Wow thank you, I didn't delete the HDR metadata in cru. Everything work fine for me !
quorrA
Post by quorrA » 24 Feb 2021, 11:38
Hi guys, I have a problem with vg259qm.
My windows display settings showing 279.857hz.
and when I look at settings with cru, I see it is different from the default settings shared on the forum
