BenQ Zowie XL2546K 240hz TN
axaro1
Re: BenQ Zowie XL2546K 240hz TN
Post by axaro1 » 08 Apr 2021, 08:12
Ziehesh wrote: ↑
08 Apr 2021, 08:06
And i have a little trouble with Black equalizer, when it 0 its ok, but when i set 1 White area go dark, and little yellow, its normal???
Yes, Imo both 0 and 1 look ugly.
Stock it's set to 5 so I wouldn't go lower.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
Ziehesh
Post by Ziehesh » 08 Apr 2021, 08:34
On 2540k color look better and be?
Xl 2546
axaro1
Post by axaro1 » 08 Apr 2021, 08:38
Ziehesh wrote: ↑
08 Apr 2021, 08:34
I have no idea, there are no 2540k reviews yet.
I assume that the only way to get colors right on TNs is to get a colorimeter and manually do it yourself.
*= currently owned
Falkentyne
Post by Falkentyne » 08 Apr 2021, 14:35
axaro1 wrote: ↑
08 Apr 2021, 08:12
Ziehesh wrote: ↑
08 Apr 2021, 08:06
Are you in standard mode?
Stock for Standard Mode should be 0, not 5. The FPS/RTS presets have different values because the color, sharpness and gamma settings are different.
Going from 0 to just 1 on my XL2746S (gamma=5) raises the red and blue gamma points considerably, at the 45% slider, from 2.15 / 2.2, to 1.9 !! So there's no way "5" can be default unless it's part of another picture mode.
http://www.lagom.nl/lcd-test/gamma_calibration.php
axaro1
Post by axaro1 » 08 Apr 2021, 14:42
Falkentyne wrote: ↑
08 Apr 2021, 14:35
I'm on edited FPS 1 mode, should I edit from Standard mode for better color accuracy? Am I just doing it wrong?
Is FPS 1 mode the same as Standard mode assuming that every single setting is the same?
*= currently owned
Falkentyne
Post by Falkentyne » 08 Apr 2021, 14:54
axaro1 wrote: ↑
08 Apr 2021, 14:42
Falkentyne wrote: ↑
08 Apr 2021, 14:35
I'm not sure.
On my XL2746S, it seems that setting FPS1 modes and Standard Modes to the exact same values results in the same image (EDIT Nope it doesn't). But I haven't spent time going through it with a fine tooth comb. I do remember that on the older Benq monitors, the FPS and RTS modes both did different things to the blue and green (and even the brown) color channels, causing them to look drastically different even with RGB set at 100% on each channel. e.g. FPS1 mode made blue look more like sky blue, red was almost scarlet, browns looked more reddish, and in RTS mode, green looked almost pastel like. I'm guessing this was something low level with the Hue and Saturation channels that the user simply did not have access to on the older Z series monitors with the Mstar scaler. I haven't seen those subcolor shenanigans on the XL2746S though.
What *i can* see is that the factory menu seems to have these settings exposed to the user at least.
https://i.imgur.com/jYtWYmL.jpg <---standard mode
*EDIT* I'm wrong.
the FPS and RTS modes do change the internal settings.
This is FPS set to the same OSD values as standard Mode.
https://i.imgur.com/U1p8GfL.jpg
Sorry for the ugly image. I forgot my phone camera doesn't like blur reduction.
So, Yes you're doing it wrong. Calibrate from Standard mode by saving Standard Mode to a S-switch profile first, then go from there.
BTW you can change those subcolor settings in the factory menu. What I do not know is if it survives a refresh rate change or a power on/off cycle or not, or if it's saved to the S-switch or gamer profile and can be recalled later. I doubt it is, since the "OD Gain" resets (back to the default values for AMA off/high/premium) on any refresh rate switch.
Ziehesh
Post by Ziehesh » 08 Apr 2021, 16:49
I see zowie 2411p and colors on him are beautiful, but in 2546k no good colors
Xl 2546
Ziehesh
Post by Ziehesh » 09 Apr 2021, 04:52
The 2546k does have a problem with the black equalizer. It slightly yellows the image and when it switches 0 to 1, the light areas become darker, who has the same problem, check. The black equalizer should not darken the light part of the image, this is observed on my monitor, there is no such problem on 2546.
Xl 2546
Boomchakadah
Post by Boomchakadah » 09 Apr 2021, 05:28
Ziehesh wrote: ↑
09 Apr 2021, 04:52
My XL2546K has the same issue.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
Ziehesh
Post by Ziehesh » 23 Apr 2021, 10:13
Boomchakadah wrote: ↑
09 Apr 2021, 05:28
Ziehesh wrote: ↑
09 Apr 2021, 04:52
Can u give me photo when be is 0,and when be is 1,i give it in zowie support for fix it, im sell my 2546k
Xl 2546
