Since you have a monitor with the reflex latency analyzer what sort of reduction in input lag did you see?pox02 wrote: β27 Apr 2021, 08:05yeah![]()
so happy so responsive no need emi filters anymore![]()
the magic is to get Very high shielded power cord
https://streamable.com/tv8ug0
ashrr
pox02
i dont care about the reflex latency analyzer im just playing feels fast responsive no need moreashrr wrote: β27 Apr 2021, 08:10Since you have a monitor with the reflex latency analyzer what sort of reduction in input lag did you see?pox02 wrote: β27 Apr 2021, 08:05yeah![]()
Blonekql
What power cord you get? Can you link it?
pox02
im using 250V cable 10A from furman but i dont know the version of it
u can use this one https://www.amazon.com/gp/product/B01AK ... UTF8&psc=1 those cables are very high shielded
f1ndus
after many years and many many tests i know that problem is causing RFI/EMI and ofcourse maybe someone have problem with electricity somehow and its unstable, but for this and for many people the main source is RFI, you can only shielding, but shielding cables its not main point, main point its shield full discharged PC, maybe 3+ days without turning on and then put to faraday cage or full metal thick CASE, i am not talking cases for servers 1mm but DIY case from 1CM thick metal, ofcourse there is problem monitor, monitor shielding its something like impossible..
yes i am that people who tried online ups, filters, and analysis electricity in our house, everything was fine and problems still persists for many years.
t
t
pox02
f1ndus wrote: β27 Apr 2021, 09:31after many years and many many tests i know that problem is causing RFI/EMI and ofcourse maybe someone have problem with electricity somehow and its unstable, but for this and for many people the main source is RFI, you can only shielding, but shielding cables its not main point, main point its shield full discharged PC, maybe 3+ days without turning on and then put to faraday cage or full metal thick CASE, i am not talking cases for servers 1mm but DIY case from 1CM thick metal, ofcourse there is problem monitor, monitor shielding its something like impossible..
t
why not try Isolation transformer ? like this one
https://www.amazon.com/Tripp-Lite-IS180 ... B00008N6S7
its little bit expensive but i think its should fix ur problem
f1ndus
im not expert aboute this products, i tried many things but for me only one chance how to fix it its shielding, you cant reduce radiofrequency interference with filters or some products, its in air and in free space.. and pci-e slot on mbs is scientifically proven they have problems with it, also audio/video cables shielded from made its not enough.pox02 wrote: β27 Apr 2021, 09:42f1ndus wrote: β27 Apr 2021, 09:31after many years and many many tests i know that problem is causing RFI/EMI and ofcourse maybe someone have problem with electricity somehow and its unstable, but for this and for many people the main source is RFI, you can only shielding, but shielding cables its not main point, main point its shield full discharged PC, maybe 3+ days without turning on and then put to faraday cage or full metal thick CASE, i am not talking cases for servers 1mm but DIY case from 1CM thick metal, ofcourse there is problem monitor, monitor shielding its something like impossible..
t
Next steps i want try is :
Make DIY full metal box with welding for PC to put in, 1 CM metal plate.
Discharge PC, dont turning on for 3+ days.
buy optic fiber HDMI which cant pickup noise RFI
and buy new monitor and this is that questione, shielding monitor is hard
pox02
f1ndus wrote: β27 Apr 2021, 09:50im not expert aboute this products, i tried many things but for me only one chance how to fix it its shielding, you cant reduce radiofrequency interference with filters or some products, its in air and in free space.. and pci-e slot on mbs is scientifically proven they have problems with it, also audio/video cables shielded from made its not enough.pox02 wrote: β27 Apr 2021, 09:42f1ndus wrote: β27 Apr 2021, 09:31after many years and many many tests i know that problem is causing RFI/EMI and ofcourse maybe someone have problem with electricity somehow and its unstable, but for this and for many people the main source is RFI, you can only shielding, but shielding cables its not main point, main point its shield full discharged PC, maybe 3+ days without turning on and then put to faraday cage or full metal thick CASE, i am not talking cases for servers 1mm but DIY case from 1CM thick metal, ofcourse there is problem monitor, monitor shielding its something like impossible..
t
do like this on ur new monitor bought two chokes for ac power and gonna use optic hdmi
ashrr
What? Since you said you don't care what the latency analyzer says your input lag is then I'm guessing you saw normal values (around 12-15ms depending on game and settings) but still felt you had some input lag problems? If the latency analyzer shows ~14ms with high emi or whatever then still shows 14ms with your $1000 transformer then that was some expensive placebo.pox02 wrote: β27 Apr 2021, 08:15i dont care about the reflex latency analyzer im just playing feels fast responsive no need moreashrr wrote: β27 Apr 2021, 08:10Since you have a monitor with the reflex latency analyzer what sort of reduction in input lag did you see?pox02 wrote: β27 Apr 2021, 08:05yeah![]()
https://streamable.com/tv8ug0![]()
gadpaw
mem cache freeblackmagic wrote: β27 Apr 2021, 14:16when i install a app or game and meanwhile switch, tab-in again to online match...then i could notice and see improvements...
unstable mem reason inputlag, freezes ... etc
for test:
1. load mem 51%+ percent
2. run game
3. free load mem in p. 1
4. start program to free mem cache (islc, freezkiller (in ryzen dram calc) ...)
5. after ~1h u get game play with min input lag and max smooth, but this state degrades after time
