Best router for gaming ?
Mugabi
Post by Mugabi » 02 May 2021, 18:37
Hello i have contacted my isp regarding improving some network features i saw alot of users talk about here, and they told me, in order to get those settings, you have to buy a third party router. So, what is the best price sensible router i can get ? And what differentiate routers from one another when it comes to gamin
victor910
Re: Best router for gaming ?
Post by victor910 » 02 May 2021, 20:29
cisco
1000WATT
Post by 1000WATT » 02 May 2021, 22:59
Mugabi wrote:
02 May 2021, 18:37
What settings? not enough information. What type of connection, what speed, and what do you want?
pwn
Post by pwn » 03 May 2021, 07:19
it does not matter
you cannot control what the isp uses
redbull2k
Post by redbull2k » 03 May 2021, 13:38
Take a look at dumaos on netgear.
Mugabi
Post by Mugabi » 03 May 2021, 23:41
1000WATT wrote:
02 May 2021, 22:59
Mugabi wrote:
02 May 2021, 18:37
business package with packet priority handling in the network and with nrt-VBR
(because packet priority handling is not available for regular customers)
- disabled DLM on your profile that is assigned to your customer account (DSL, ADSL, VDSL connections)
(because DLM interferes with UDP packets that FPS games are using)
- if DLM can't be disabled, at least ability to choose interleaving depth (DSL, ADSL, VDSL connections)
(call your ISP and tell them to set the lowest possible interleaving depth on your profile)
amezibra
Post by amezibra » 06 May 2021, 15:51
- just get an Ubiquiti ER4 and activate smartqueue (fq codel)
- you can also find specific configuration to give your gaming traffic priority.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 06 May 2021, 16:20
