G-sync does not work in CSGO in full-screen mode.
Ku6epgeg
Post by Ku6epgeg » 12 Jun 2021, 12:43
Hello. My config:
CPU Intel Core i7-10700F
GIGABYTE Z490 UD
MSI GeForce RTX 3070 ventus 3X OC
Samsung Odyssey C27G75TQSI
I did everything you said:
G-SYNC on
– NVCP V-SYNC set to “On”
– NVCP “Low Latency Mode” set to “On”
– In-game “Wait for Vertical Sync” set to “Disabled”
– In-game “Display Mode” set to “Fullscreen”
– in-game “fps_max” command set to “237”
But when starting the game, the hertz of my monitor is in a static position, always 240. And if I change the MSAA parameter in the graphics settings, for example, or any other, then the hertz on the monitor will become active.
Tell me, how do I get G-sync to work immediately after starting the game?
Re: G-sync does not work in CSGO in full-screen mode.
Post by RealNC » 12 Jun 2021, 13:19
Maybe the fps limiter doesn't cap correctly right away. IIRC, there's two limiters in CS:GO. One for actually playing (fps_max), and one for when being in the main menus (fps_max_menu). So try and see what happens after you load a map.
Ku6epgeg
Post by Ku6epgeg » 12 Jun 2021, 13:32
After loading the map, nothing happens, the monitor hertz is also static at 240.
Only if you change the graphics settings in the game, such as MSAA or whatever else, will G-sync become active.
