SYNC FAILURE
Gizmmo
SYNC FAILURE
Post by Gizmmo » 17 Jun 2021, 11:28
Hi,
i have an 144hz monitor and when i try to do the Test UFO, i get the error:
SYNC FAILURE: Unable to VSYNC. Try closing all apps and browser tabs.
I tried:
- rebooting
- closing all apps
- reinstalling drivers (monitor and gpu)
- trying different browser. I tested on latest version of Mozilla
- trying a different display port cable
- trying a different display port on GPU
The only time it synced was with a HDMI cable, but that limited refresh rate at 100hz
I added the animation timed graph.
2021-06-17 19_19_35-Window.jpg (233.73 KiB) Viewed 13619 times
Re: SYNC FAILURE
Post by Chief Blur Buster » 17 Jun 2021, 16:30
Background CPU processing shows up in that graph. Browsers are super sensitive to this.
Temporarily reboot with no system tray apps and see what happens. Some RGB software are inefficient, for example, while old versions of a specific cloud sync app has also been a culprit.
Gizmmo
Re: SYNC FAILURE
Post by Gizmmo » 17 Jun 2021, 16:41
I uninstalled 2 RGB programs, Aorus from gigabyte and Aura from Asus. It works fine now.
Oh man, sorry for wasting your time, I've read RGB programs could be a problem in another thread where
you've already answered. I dunno what i was thinking and why i haven't tried that first.
Thanks a million!
Re: SYNC FAILURE
Post by Chief Blur Buster » 17 Jun 2021, 16:43
Yep.
Fortunately, only half of the RGB software may cause problems, others such as Razer is written very efficiently.
Was ASUS or Aorus the bigger problem?
Gizmmo
Re: SYNC FAILURE
Post by Gizmmo » 17 Jun 2021, 16:50
I don't know. I am guessing gigabyte was the bigger problem because it was running as a service. The Asus one was just a bios toggle for lights on/off.
Re: SYNC FAILURE
Post by Chief Blur Buster » 17 Jun 2021, 17:59
Gizmmo wrote:
17 Jun 2021, 16:50
If you know which app was the CPU hog, let me know.
I may want to strategically release an article to, ehm, perhaps “honestly sensationalize” this newsworthy “RGB software creating INPUT LAG!!!1!” Issue (to get them to fix the problem) once we got enough sample reports from users. It’s starting to become a real problem with inefficiently-programmed RGB software. But we need more user reports to isolate the problem RGB apps…
Briefly turn on the BIOS and let me know if ASUS hardware Aura Sync seems to be invisible on the TestUFO workload. It may be one of the “good ones” including Razer’s.
