Discorz
VIP Member
Post by Discorz » 15 Jul 2021, 05:06
Blehhh wrote:
15 Jul 2021, 04:58
Its OD level inbetween 60 and 80 for VG259QM.
On VG279QM is inbetween 80-100, more like OD85/90.
Blehhh
Post by Blehhh » 15 Jul 2021, 05:08
Discorz wrote:
15 Jul 2021, 05:06
Blehhh wrote:
15 Jul 2021, 04:58
yeah using VG259QM , in rtings website it says OD 60 its better than OD 120 and OD 80 not sure which is the best, i trust this forum, which is the most optimal settings?
once you on 120OD is your monitor able to change back to default OD 60 or OD 80?
axaro1
Post by axaro1 » 15 Jul 2021, 06:07
Blehhh wrote:
15 Jul 2021, 05:08
Don't listen to RTings.
OD120 is arguably the best overdrive at 280hz, especially if you use ShadowBoost since it looks like only the darkest transition seem to suffer from overshoot and equalizing dark levels can effectively remove overshoot even further.
OD80 is a good alternative, IMO there is a little bit too much overshoot but it's definitely usable.
Blehhh wrote:
15 Jul 2021, 05:08
Yes
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
Blehhh
Post by Blehhh » 15 Jul 2021, 06:12
axaro1 wrote:
15 Jul 2021, 06:07
Blehhh wrote:
15 Jul 2021, 05:08
Blehhh wrote:
15 Jul 2021, 05:08
Yes
Thanks , to unlock OD 120 just follow ur first post?
so theres zero to no harm in unlocking OD120 right?
thanks for helping me out :)
axaro1
Post by axaro1 » 15 Jul 2021, 07:44
Blehhh wrote:
15 Jul 2021, 06:12
Yes, follow this guide. There is no harm in using OD120.
*= currently owned
ekajjj
Post by ekajjj » 16 Jul 2021, 07:24
Can anyone tell me a bit more regarding VividPixel? I really like this monitor and have tried using 25-50 on the setting, but having seen mosts from a few years back regarding VividPixel on older ASUS models it was suggested it may increase the response time. If anyone is knowledgeable on this I'd greatly appreciate some information.
Thanks
zonk
Post by zonk » 22 Jul 2021, 10:56
hey I just followed the steps, nice Thread! been a while is there any updates?
ryshan53
Post by ryshan53 » 22 Jul 2021, 16:25
Max_hz wrote:
17 Aug 2020, 09:26
Thanks, nice find! I wil try it in game and looks how this "OD 120" feels, at ufotest for me it looks like between OD 60 and OD 80.
Must be a bug in the FW nevertheless it could be very useful, will report later.
Good idea to make a exclusive thread for the VG259QM, btw I have FW MCM104 also.
I cant change mine to 120 od, whenever i press od strong weak off, and press exit or leave, there is no 120 od option and it always resets to od strong on. What do I do?
SkooR
Post by SkooR » 23 Jul 2021, 17:33
Hello guys
Im thinking of going to xl2546k instead of my vg259, is there any big difference i mostly playin warzone
Also what is best od for 180hz should I go with 120od ?
ryshan53
Post by ryshan53 » 23 Jul 2021, 20:14
axaro1 wrote:
15 Jul 2021, 07:44
Blehhh wrote:
15 Jul 2021, 06:12
whenever i turn off od strong weak off and press exit, it just keeps going back to on. How do i save it or actually turn it off?
