can AMD SAM cause input lag?
readtext
Post by readtext » 29 Jul 2021, 13:14
can amd sam cause input lag because how it works? because the distance to the cache is closer than the ram of the gpu.
"AMD Smart Access Memory-Technologie"
Eonds
Re: can AMD SAM cause input lag?
Post by Eonds » 30 Aug 2021, 14:00
In theory it lowers latency. There's other "technologies" that you should be concerned about affecting input lag from the GPU itself.
