Locked
Dzekson22
Post by Dzekson22 » 24 Jul 2021, 14:15
what is the best psu to reduce emi noise? corsair, seasonic?
dervu
Post by dervu » 24 Jul 2021, 15:07
If you have input lag issues then changing PSU with better EMI filter will not help. Source of this problem is not in the range of regular PSU EMI filter.
Dzekson22
Post by Dzekson22 » 24 Jul 2021, 16:00
I changed the power supply to chieftec gps 700a8 i have higher input lag than psu silentiumpc 550w m2 gold, more power the power supply increases the emi noise? whether the 12v line can cause delays? Image 8pin Voltage drop to 11v
Bobo
Post by Bobo » 24 Jul 2021, 17:49
your new psu does not provide power that is as clean as the previous one does.
dervu
Post by dervu » 30 Jul 2021, 11:54
Guys, I have the device during tests. Stay tuned for more updates. :)
f1ndus
Post by f1ndus » 30 Jul 2021, 13:29
dervu wrote: ↑
30 Jul 2021, 11:54
what is that? :shock:
hiro
Post by hiro » 30 Jul 2021, 14:59
Did someone tried the torus power Toroidal stuff ? Its quiet expensive like 2k+, it says "Torus Power
products restore incoming power to its clean original state". Maybe i give it a try.... have suffered from this problem for too long 6 years bad daytime better at night.
agendarsky
Post by agendarsky » 01 Aug 2021, 20:30
Dzekson22 wrote: ↑
24 Jul 2021, 16:00
i also switched to from cv650 to hx750 modular with multi-rail support. it makes no difference, from hw side for me having fclk 400 really helps it makes my hit registry and recoil much much better. however just to support that theory that electricity has affect on inputs i came with two videos that proves it.
in the first video i show how my display which is dell alienware aw2518hf 240 hz , 0.5ms monitor restarts and shows error message "
.Unsupported audio format. Please set the audio output on your aido player to Pulse-code modulaton (PCM) if avaiable
when i move with my electrical blinds. Doesnt happen if monitor is on UPS (which has double-conversion) or if i use displayport ( this was recorded on hdmi 2.1). So now victor910 tell us again how this is server sided input lag and electricity is no factor here. Just to reply you let me quote
"victor910 Input lag" manipulation coming in 2002 with cs 1.5, not 2009.
Perfect recoil with 60 fps I'm explained before, take pills Guys and reading carefully what I wrote before.
I'm really wanna help you, but just today ;)
i wasnt talking about hardware-software optimalization guides , i was talking about first thread where the guy called "schoof" completely described this issue, it was not the classic input like when you have vertical synchronization or on or difference between pre-rendered frames 1vs3, he described how everything is hard to suddenly, he told about things like how duck jumping and bunny hoping became impossible, how keyboard pressed is delayed so you cant strafe, how you cant track because mouse feels very heavy, floaty and unprecise even on good fps and good gaming monitor. it seems like the more you want try to track enemies the mouse feels more off and delayed instead.Its not classic input lag.
Here is video 1 https://www.youtube.com/watch?v=1omXnZ7AA80.
In video 2 i recorder electrical buzz everytime i touch my keyboard , it also records activity like loading or sometimes mouse clicks.
https://www.youtube.com/watch?v=Ehpj9IR4EGw its most hearable at 0:45, 1:00 or 1:15
deama
Post by deama » 01 Aug 2021, 21:06
So a while ago I bought some Tacima mains conditioners from amazon, 2 of them, and plugged them both into my socket extension, where my PC and monitor are plugged in. I gave it a few days, didn't feel anything, but I found out I was able to overclock my GPU (2060 super) by +100mhz (1650 to 1750) which was nice.
I currently have my computer grounded to an old rusty steel rod outside my house, I'm going to replace it soon and am wondering if replacing it with a nice new copper grounding rod will do anything.
Locked
