Hello Chief,
Since you've made a very good test with CS GO + G-Sync and you measured the input lag etc, many people are also interested to know what would be the results with Quake Live. Can you maybe one day try to run a test on Quake Live with G-Sync then?
Thanks in advance.
G-Sync and Quake Live
Re: G-Sync and Quake Live
Thanks for the suggestion!zb0t wrote:Hello Chief,
Thanks in advance.
I'm trying to get my hands on the ASUS ROG PG278Q, and when/if I do, this will be added to the test suite.
zb0t
Wow, thanks a lot Chief <3 can't wait!
