Looking for test performance feedback | Pursuit camera ghosting test on Eve Spectrum ES07D03
Javild
Post by Javild » 21 Aug 2021, 09:52
Hi! After Mark shared his guide over at eve.community, I decided to attempt to capture the performance of the Eve Spectrum ES07D03 with the BlurBuster's tuned strobing settings and without it to show the difference. I'd really appreciate it if I could get some feedback on these attempts to see if they're suitable to share or how I can improve and attempt it again.
Here's the video I recorded with my camera setup on a slider at the level of the screen. In this one, long pulse width strobing is enabled with response time overdrive set to "Normal" and low-latency mode turned on. I was able to get a few frames from this one that looked very clear and I believe had accurate tracking.
youtu be/64y-raJhIJM
For this next one, strobing is turned off, response time overdrive is set to "Normal", and low-latency mode is on. I wasn't able to get any individual frames from this one, as the video looks very blurry, no matter how I adjusted the camera.
youtu be/5bPnBY49jD0
Here are the images I was able to get from the first (strobing) video.
4K 144Hz Pursuit, Without Large-VT Tweaks
Strobing 1.png (326.84 KiB) Viewed 32254 times
Strobing 2.png (415.62 KiB) Viewed 32254 times
Strobing 3.png (383.03 KiB) Viewed 32254 times
4K 100Hz Pursuit, Without Large-VT Tweaks
[EDIT: 4K 100Hz added below]
Javild
Re: Looking for test performance feedback | Pursuit camera ghosting test on Eve Spectrum ES07D03
Post by Javild » 21 Aug 2021, 15:14
Sorry, I wasn't able to upload the videos directly because of their size, and I'm not able to embed any external videos in the post.
Post by Chief Blur Buster » 29 Aug 2021, 18:00
Javild wrote: ↑
21 Aug 2021, 15:14
Hello Javid,
Only seeing thigs post now. Thanks for posting these!
These are very good first-attempt pursuits!
Can you please post YouTube links by deleting the https, deleting the www, and deleting all periods, such as "youtu be/asdfasdfasd"? New forum members (up to about a few posts) have link posting blocked until out of new forum member status.
You will want to improve the defocussing siutuation (camera focus) and non-display-blurring situation (camera vibrations), as follows:
Discorz
VIP Member
Post by Discorz » 05 Sep 2021, 05:22
Good attempt!
Iso and shutter speed look good. Maybe improve focus and lower the camera height or angle to align all 3 cyan rows to middle. You can also do a fullscreen crosstalk test.
Javild's video links from first comment:
1. https://youtu.be/64y-raJhIJM
2. https://youtu.be/5bPnBY49jD0
I'd recommend to add basic monitor settings to yt video description
Which one is 100Hz tho?
