You have issue without Adaptive Sync ?axaro1 wrote: ↑01 Sep 2021, 03:17Same, I'm using OD120 at 280hz but I enable Adaptive Sync, there is some overshoot since OD120 scales by increasing the overshoot the lower your fps go compared to static 280hz with VRR OFF that has a more consistent overshoot pattern (that is limited to very few pixel transitions + it can be mitigated by Shadow Boost).Jefa35 wrote: ↑01 Sep 2021, 03:01I got the VG259QM recently, if you are on PC you'll run the monitor @280Hz and won't be below 200Hz, your framerate won't affect response time either.
You can check Rtings review for more precise data regarding response time and overshoot, but with an OD of 60, 80 or 120 you shouldn't notice any disturbing overshoot or ghosting. I run OD at 120 and have no issue (OD 120 is basically a mix between OD 60 and 80, it's not a very intense OD setting as you could think).
About the ELMB, I don't use it. I didn't notice much difference between ELMB ON and OFF except the downsides of it : way lower brightness and a tad more input lag.
In Apex when my fps go as low as 140 I honestly don't notice any overshoot while playing and input lag is very consistent.
I personnally disabled it, didn't really try it out yet since I only have the VG259QM for one week now. But I've a decent PC (10700K 5GHz, RTX 3070) and easily run games like Destiny 2 and Apex at 200FPS so didn't notice any screen tearing.
By the way I noticed you also have the XL2546K, which monitor you ended up maining ? Is there such a difference of raw motion clarity between these two ?
