Hence Benq lists the color depth of this monitor as 16.7 million, it should be 8bit, also note that the model i have is XL2720Z-B "as written in the back of the panel", from basic tests i conducted it proves that this TN Panel ain't no easy , in general quality "after calibration" it knocked out an asus VG248QE "after calibration", so does that mean that it is an 8bit panel?
From what i know 8bit TN panels do exist, but rarely do they manufacture such TN panels, i got it hooked up to my gtx 780 classified via DVI-D, well calibrated and thanks to the almighty it is running quite well, i also checked out the blurbusters strobe utility and it has proven itself quite versatile, the motion tests are quite neat too
Thank you for reading this topic and i apologize if i have mistakenly posted this where it doesn't belong,
Some help would be greatly appreciated
