I tried side by side:ahk1221 wrote: ↑27 Dec 2021, 17:04Hello all, currently trying to decide which monitor to buy.
Looking for preferably a 144-240hz monitor, at 1080p. I play competitively a lot, more than anything, but I still do like to play story mode games here and there.
I currently have a Viewsonic XG2405, its a 144Hz 1080p IPS monitor, and it has god awful response times, its basically the same panda panel as the one in the older 24G2 and idk how reviewers can say its good. pic for reference: https://www.techporn.ph/wp-content/uplo ... Test-3.jpg
So, naturally, I am a bit put off by IPS monitors. I don't want to make the same mistake again and buy another IPS which I end up regretting. However, at the same time, I do see that the top IPS monitors like the VG259QM and the MAG251RX have really good motion blur, so now I'm at a loss.
On the other hand, the Omen X 25 seems to be really good for its price, only issue seems to be its colors, which again dont seem that bad. Can someone guide me and help me buy a monitor thats worth its money and wont make me gouge my eyes out because of the motion blur.
Thanks in advance.
omen x25
xl2546k
Mag251rx
acer xv252qf
best monitor on response times is Omenx25, no one else can compete.
best monitor on input lag and responsiveness and fluidity is acer xv252qf, no one else can compete
Mbr, bls or whatever you want to call it, I don't like it on any monitor, it introduces miscro vertical tears that bother me a lot, I prefer to use monitors with their natural response time without tricks.
colors:
Omen x25 has a good image, no problem in this sense, compared to xl2546k it has fewer adjustments, it does not have the color vibrance so to push up the colors you will have to rely on your video card.
you have to decide based on your priorities, if for you the most important aspect, the one you can't give up, is the response time, take omen x25, it's amazing about this.
If input lag and responsiveness are the most important to you, get the Acer xv252qf
if the question is:
is there much difference in input lag and reactivity between omen x25 and acer xv252qf?
the answer is yes, acer is obviously more responsive and faster, even when you don't do 390 fps acer is more responsive
if the question is:
is there much blur difference between omen x25 and acer xv252qf?
the answer is yes, omen has much less blur than Acerxv252qf
P.s
if you can wait……wait for the tn to come out at 480hz, that will be the best of everything
