VRR STROBING Monitors List
sssouthpaw
Re: VRR STROBING Monitors List
liquidshadowfox
Please report your findings on the VRR + backlight strobing quality if you can. I am a VERY big fan of MSI monitor OSD + app functions and if this is any better at VRR strobing than my XG27AQM, it might be the monitor to hold me over until the eve spectrum comes out.
sssouthpaw
liquidshadowfox
That's what I used when I did my analysis
sssouthpaw
liquidshadowfox
Did you at least tested the VRR + strobing? even with the defects? I want to know if there's any heavy crosstalk
if not, it's all good.
sssouthpaw
liquidshadowfox
Thanks! Make sure you enable Gsync compatible in the nvidia control panel because I don't think the monitor has Gsync compatible certification yet (I could be wrong). Prior drivers I had to enable it manually for my Asus XG27AQM
sssouthpaw
liquidshadowfox
Sounds like it's might actually be worse than my XG27AQM, damn.
